with CF they have fixed most of them but their is still jittering and some frame problems but apart from that no. the only other issue i see is the 650W PSU is a real push with too r9 290x cause it says in the spec for 2x of them you sshould have at least 700w :L so not much room OC wise
Current Build :
CASE: Fractal Design R4 w/Window CPU: Intel 4930K,  RAM: 16GB Ripjaws Z 2133Mhz  Cooling: H100i  MotherBoard: Asus P9x79 Pro , PSU: CS750M   Storage: 2x Samsung 840 Pro 256Gb , 1Tb Seagate Barracuda, 500GB WD Black,  Graphics: Gigabyte GTX 780 Windforce 3GB,  Monitors: AOC G2460PG ( G sync monitor), Edge10 24" 1080p , 24" 1680*1020p monitor ( LCD)  Microphone: Blue Yeti  Keyboard: Cougar 700k  Phone: Samsung Note 3  Headphones: Sennheiser HD598
Laptop:
 CPU:
4710MQ  Ram: 8GB 1600MHz Storage:120Gb 840 Evo + 1Tb 5400Rpm HDD  Graphics: GTX 850M 2GB   Screen: 1080p IPS
https://linustechtips.com/topic/94078-problems-with-cf-or-sli/#findComment-1262468
780ti for sure crossfire wont scale that well in most of the time and you will run in to more problems and worse game experience overall
https://linustechtips.com/topic/94078-problems-with-cf-or-sli/#findComment-1262470
Get 2 R9-290 for the price of a single 780Ti if that's possible in your country, in France a 290 cost 350€ and a 780Ti costs 700€, I'll let you do the math.
VIDEO GAMES                                  Max Power Build Log
https://linustechtips.com/topic/94078-problems-with-cf-or-sli/#findComment-1262474
780ti but not for the reasons listed above...
The frame pacing issue is completely solved with the new R series, only the older 7000 series still has a few issues with DX9 games.
Also if you went for two 280x's i wouldn't want to run them on a 650w that you got "free" its probibily terrible quality, Also if you run a game that doesn't have a Crossfire profile you will be cutting your GPU power in half.
Always go for the more powerful card over two medium cards.
Quack 🦆
https://linustechtips.com/topic/94078-problems-with-cf-or-sli/#findComment-1262483
I would go with a non reference 290 and 650w won't be enough for cf/SLI
i will be buying from UK.
also if possible can you send me where you have found those offers on the 290
If i will buy a 290 is going to be a sapphire tri-x
Now from those two
the 290 sapphire eont be as good as a 780 ti. If possible i can find or you people could send me a cheap 780ti. or someone who is selling it.?
https://linustechtips.com/topic/94078-problems-with-cf-or-sli/#findComment-1262511
so the answer is to get a single cpu.
https://linustechtips.com/topic/94078-problems-with-cf-or-sli/#findComment-1262532
Yeah, one more powerful GPU is nearly always a better option than 2 weaker ones, not to mention I have calculated the wattage needed for two 280x's not OC'd with an FX8320, a H80I an SSD a HDD to be about 740 Watts so them selling you a 650 Watt one with they cards in an absolute disgrace.
Case: Corsair 460X RGB bby, CPU: I5 8600K, Motherboard: MSI B360M PRO-VDH, RAM: 8GB Hyper X 2400MHz , Graphics Card: GTX1060 6GB, PSU: Corsair RM750x,
Cooler: BEQuiet!  Pure Rock Slim SSD: Kingston 240GB, HDD: 2TB Seagate Barracuda
https://linustechtips.com/topic/94078-problems-with-cf-or-sli/#findComment-1262562
do you have a 780ti
can you tell me where to find a cheap one?
https://linustechtips.com/topic/94078-problems-with-cf-or-sli/#findComment-1262596
do you have a 780ti
If I did own one I would never sell it xD, A cheap 780Ti, not many of them:P, what currency?
https://linustechtips.com/topic/94078-problems-with-cf-or-sli/#findComment-1262614
https://linustechtips.com/topic/94078-problems-with-cf-or-sli/#findComment-1262626
https://linustechtips.com/topic/94078-problems-with-cf-or-sli/#findComment-1262693
Now from those two
780Ti, isn't worth the extra money IMO, because the 290 is almost as good, 5-7FPS usually
https://linustechtips.com/topic/94078-problems-with-cf-or-sli/#findComment-1264463
And much cheaper as well. In my neck of the woods, a GTX780 Ti cost >1000 local currency, while an R9 290X can be had for around half of that, quite simple math involved actually, don't you think? ;)
I'd gotten a pair of R9 290Xes and they cost about the same as a GTX Titan in local currency......buy smart, don't just look at the brand. Just look at my keyboard collection, do you see a Razer mechanical keyboard anywhere? That's because I think Razer mechanical keyboards offer terribad value (no, I didn't misspell that word) though it's the most well known due to its marketing.
 Main Rig: AMD AM4 R7 5700X3D (8C/16T) + TR Phantom Spirit 120 EVO | Gigabyte X570 Aorus Xtreme | 2x 16GB Kingston Fury Beast DDR4 3600 | XFX MERC 310 RX 7900 XTX | 256GB Sabrent Rocket NVMe M.2 PCIe Gen 3.0 (OS) | 4TB Crucial P310 NVMe M.2 PCIe4x4 | 2TB TG Cardea Zero Z440 NVMe M.2 PCIe Gen4x4 | 4TB Samsung 860 EVO SATA SSD | 2TB Samsung 860 QVO SATA SSD | 6TB WD Black HDD | CoolerMaster H500M | Corsair HX1000 Platinum | Logitech G915 + G303 Shroud Ed + 8BitDo Ultimate 2.4G | iFi Micro iDSD Black Label | Philips Fidelio B97 | C49HG90DME 49" 32:9 144Hz Freesync 2 | Omnidesk Pro 2020 48" | 64bit Win11 Pro 24H2
2nd Rig: AMD AM4 R9 5900X (12C/24T) + TR PA 120 SE | Gigabyte X570S Aorus Elite AX | 2x 16GB Patriot Viper Elite II DDR4 4000MHz | Sapphire Nitro+ RX 6900 XT | 500GB Crucial P2 Plus NVMe M.2 PCIe Gen 4.0 (OS) | 2TB Adata Legend 850 NVMe M.2 PCIe Gen4x4 |  2TB Kingston NV2 NVMe M.2 PCIe Gen4x4 | 4TB Leven JS600 SATA SSD | 2TB Seagate HDD | Logitech G613 + G703 | SOLDAM XR-1 Black Knight | Enermax MAXREVO 1500 | 64bit Win11 Pro 24H2
HTPC: AMD R7 6800H | 32GB DDR5 4800MHz | AMD 680M iGPU | 2TB SSD (2 Partitions 400GB + 1.4TB)) + 1TB SSD | Logitech G613 + G304 | Win11 Pro  24H2
Laptop: Lenovo Legion 5 Pro 16ACH6H - AMD 5800H | 32GB DDR4 3200MHz | 680M iGPU | 1TB Kingston NV1 NVMe M.2 (OS) | 4TB Lexar NM790 SSD | Win11 Pro
https://linustechtips.com/topic/94078-problems-with-cf-or-sli/#findComment-1264853
Two 280X's will perform much stronger than a single 780Ti and 650W is not enough of a PSU for them.  Downside of course is the frame time issue which AMD has mostly fixed now.
Intel Core i7 4930K @ 4.7GHz | Asus Rampage IV Extreme | 2 x EVGA GTX Titan SC (1254MHz) | 16GB Patriot Viper Extreme DDR3 2133MHz (4 x 4GB) | Corsair AX1200 | Silverstone Temjin TJ11 | Corsair Force 3 240GB (System) | 2 x Intel 320 160GB SSD (Dedicated Gaming Drives) | Hitachi Deskstar 1TB (Data) | MS Windows 10 Pro | EK Supreme HF/FC-Titan/Rampage IV Extreme blocks | Hardware Labs GTX 560/240 rads | Alphacool VPP-655 D5 pump | Bitspower mod kit/pump top/fittings/120mm res
https://linustechtips.com/topic/94078-problems-with-cf-or-sli/#findComment-1265237
