1 hour ago, suntofu said:
Hi everyone. Is it possible to remove the top panel of an H200i?
I want to pack it into a suitcase and trying to make it as small as possible.
Thanks in advance for any help!
The top panel is part of the case frame. It is not removable unless you drill out the rivets holding the panel to the frame
https://linustechtips.com/topic/940190-h200i-top-panel-removal/#findComment-11465971
