Can you even get an X99 chip for that price? The 5820K is the 'lowest end' chip on that board (I don't know all the Xeons on X99 off the top of my head, so there might be one in there too) and I can only find that i7 for 300 USD and up (which is like 200 GBP)
https://linustechtips.com/topic/939639-need-a-cpu/#findComment-11460314
I can find a 5820k on cex for 150 would that be fine paired with a GTX 760? For gaming
https://linustechtips.com/topic/939639-need-a-cpu/#findComment-11460321
That's what I'm looking into. The Xeons. Unless he buys major used here's not gonna find a X99 chip that cheap.
https://linustechtips.com/topic/939639-need-a-cpu/#findComment-11460325
Pretty much any desktop chip on the X99 platform will do the job for almost any current GPU. So yes. Particularly if you give it a little overclock.
https://linustechtips.com/topic/939639-need-a-cpu/#findComment-11460329
Short answer: yes.
Long answer: The performance of the 5820K is like the 4790K, but with 6 cores. Which is a similar performance to a non overclocked Ryzen 5 1600. Very roughly, that is the performance you will get, which will pair nicely with a GTX 760.
Anyway, now that I am comparing this chip to the Ryzen 5, it is probably not a big price difference in general, so if in the long it will be worth it.. That will be up to you.
Also, it doesn't happen often CEX has sensible prices and eBay has none.
https://linustechtips.com/topic/939639-need-a-cpu/#findComment-11460336
1 minute ago, Windows7ge said:
Pretty much any chip on the X99 platform will do the job for almost any current GPU. So yes. Particularly if you give it a little overclock.
Okay well I found a Intel Xeon E5-1220 V3 for 90 would that be fine for games like gta v?
https://linustechtips.com/topic/939639-need-a-cpu/#findComment-11460340
