Hey guys,
I just got a new PC, I've got an I5-8400 in a fractal design mini c -windowed. I've currently got a white and black colour scheme but want to get an aftermarket cpu cooler. I was thinking about either a hyper 212 or a cryorig c7. The c7 would look good but not sure.
any advice appreciated
  • CPU
    I5-8400
  • Motherboard
    Gigabyte B360 ds3h
  • RAM
    2*8gb Vengence 2400 ddr4
  • GPU
    ASUS gtx 1060
  • Case
    Fractal define c mini windowed
  • Storage
    1tb WD blue and 240gb sandisk ssd
  • PSU
    550w bronze corsair cxm (grey)
  • Operating System
    windows 10
https://linustechtips.com/topic/939475-cpu-cooler/
C7 is a loud *****, dont use it unless you absolutely have no other choice
Desktop benching:
https://linustechtips.com/topic/939475-cpu-cooler/#findComment-11458871
Hyper 212 is very good affordable standard level heatsink.
Most "top down" heatsinks don't have comparable cooling power to "tower" heatsinks.
Though for that colour theme Thermalright Macho120 SBM would be very good for low noise cooling with very good pricing and good clearance for other parts.
https://www.tweaktown.com/reviews/7810/thermalright-macho-120-sbm-cpu-cooler-review/index5.html
https://linustechtips.com/topic/939475-cpu-cooler/#findComment-11458934
2 hours ago, ItsTheDuckAgain said:
https://pcpartpicker.com/product/F3gzK8/be-quiet-dark-rock-pro-4-505-cfm-cpu-cooler-bk022
163mm height - will fit in there - and it's about as black as it can get
For locked i5 thats as overkill as you can get without going full custom loop.
H7 or H5 from Cryorig, Dark Rock 3/4 from be Quiet!, Chromax U12S from Noctua. Also both you picked are good, and will work since your CPU doesn't really need more than stock cooler to be cooled.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/939475-cpu-cooler/#findComment-11459124
Where are you shopping / located? Budget?
https://linustechtips.com/topic/939475-cpu-cooler/#findComment-11461258
