Hello, I'm new to the water cooling business. I have a NZXT Kraken x60, I believe I'm not getting what I paid for but can someone tell me if this is alright?
Specs:
i7-4770k @3.5GHz
EVGA Geforce GTX 780
16 GB 8x2 Corsair Vengance
2 TB Western Digital Caviar black HD
And so forth..
Here are my temps:
i7 Idle: min/26C Max/38C
i7 Load: min/26C Max/50C ish
GTX Idle: 29C
GTX Load: 80C
Please Comment and tell me if there is a problem with this, I'm using OCCT to run the test! Thank you very much!
https://linustechtips.com/topic/93941-big-concern-help/
Specs:
Here are my temps:
Looks perfect
Feel free to message me if you want to chat!
https://linustechtips.com/topic/93941-big-concern-help/#findComment-1261058
Specs:
Here are my temps:
What are the ambient temps mate? also is your graphics card water cooled?
Everything at stock settings or overclocked?
CPU: R5 1600 @ 4.2 GHz; GPU: Asus STRIX & Gigabyte g1 GTX 1070 SLI; RAM: 16 GB Corsair vengeance 3200 MHz ; Mobo: Asrock Taichi x470; SSD: 512 gb Samsung 950 Pro Storage: 5x Seagate 2TB drives; 1x 2TB WD PurplePSU: 700 Watt Huntkey; Peripherals: Acer S277HK 4K Monitor; Logitech G502 gaming mouse; Corsair K95 Mechanical keyboard; 5.1 Logitech x530 sound system
 01000010 01101001 01101110 01100001 01110010 01111001 00100000 01100100 01101111 01100101 01110011 01101110 00100111 01110100 00100000 01101101 01100001 01101011 01100101 00100000 01111001 01101111 01110101 00100000 01110000 01110010 01101111 00101110
https://linustechtips.com/topic/93941-big-concern-help/#findComment-1261156
temperature wise you are par with 99% of the stock clocked 4770k CPU.
unless your ambient (room) temperature is less than 16° you are fine and
the cooler is doing what it was intended for. don't know what the expectations
were, but 30° delta drop is pretty good. there is more if you undervolt the stock
multiplier by possibly another 10°. with the stock fan and OCCT you could not
complete without temperature fail (85°+).
bottom line, you got what you paid for, if you are looking for more then you deffo
need to rethink where you need to be in temperatures and go from there.
https://linustechtips.com/topic/93941-big-concern-help/#findComment-1262284
