Whst are the best cpu & case fans for my budged?
Wolf ~ IRONI
So i want a black themed (or black n silver/grey) new cpu cooler for my 7 1700 soon. It is using the stock cooler RN and i want some good 120 mm case fans also black. I was thinking of the be quoet silent wings 2 as case fans. I dont want to spend too much on everything. Just balanced
My main rig  Shardsedge
 ☟ INFO & SPECS
  • Information:
This build is made for video editing, Gaming and livestreaming.
probably 65% of this build has been bought used.
  • Specifications:
CPU  AMD Ryzen 7 1700
GPU  Sapphire RX 580 PULSE 4GB
SSD ✦ Toshiba TR200 240GB
HDD ✦ WD Black 160GB 2.5" + WD BLUE 1TB
PSU ✦ Corsair RM750X
RAM ✦ Corsair Vengeance LPX 2x4 (8GB) 3000Mhz
CASE ✦ Corsair Crystal 460X
MOBO MSI X370 SLI Plus
My old pc build  Smoke
 ☟ INFO & SPECS
  • Information:
This build was made for gaming especially, it was my second build.
i had some struggles livestreaming on it because the CPU just wasn't good enough for that.
(I do not have this build anymore)
  • Specifications:
CPU ✦ Intel i5 6500
GPU  Sapphire NITRO+ Radeon RX 470 4G D5
SSD ✦ Kingston SSDNow v300 120GB
HDD ✦ WD Blue 1TB
PSU ✦ Corsair CX450M
RAM ✦ Corsair Vengeance LPX 2x4 (8GB) 2400Mhz
CASE ✦ Sharkoon S25-V
MOBO ✦ MSI H110M ECO
Best Black/B%W cooler? Dark Rock Pro 4 or Cryorig R1 Ultimate.
For anyone who likes to look out options, case and RAM will fit all coolers. R1 is among largest.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
2 hours ago, just tilt said:
Well, what's the budget? :D
2 hours ago, Christophe Corazza said:
I'm not very good with telepathy so you should mention your budget ;)
10 euro max per fan. And cpu cooler just list up some good ones pls
 ☟ INFO & SPECS
  • Information:
  • Specifications:
 ☟ INFO & SPECS
  • Information:
  • Specifications:
CPU ✦ Intel i5 6500
HDD ✦ WD Blue 1TB
Thermalright Macho 120 SBM should be available for very good price.
It leaves DIMM slots, motherboard attaching screws and uppermost PCI-e slot accessible.
https://www.tweaktown.com/reviews/7810/thermalright-macho-120-sbm-cpu-cooler-review/index5.html
While lacking marketing hype Thermalright has been doing very good coolers for 15 or so years and at very good price.
Also that crystall ball never works when you need it...
Ooooh man... you tell me...
I've thrown that thing out already a long time ago! :P
Where are you shopping / located? Budget?
What case and ram are you using?
The Netherlands
On 6/19/2018 at 11:58 AM, geo3 said:
Noctua NF-P12 should be around 10, they're $14 US and I think the Euro is a little more than a dollar. They have a grey one if you don't like the default Noctua color scheme.
14 euro or dollar is still over the max tho. But thankyou for the reply!
 ☟ INFO & SPECS
  • Information:
  • Specifications:
 ☟ INFO & SPECS
  • Information:
  • Specifications:
CPU ✦ Intel i5 6500
HDD ✦ WD Blue 1TB
13 hours ago, Wolf ~ IRONI said:
The Netherlands
What case and ram are you using and what's your budget?
corsair 460x. and the corsair vengeance LPX. sorry for the late reply btw. 12.50 euro max per fan (EU) (NL) and i think ill just stay with the wraith spire
 ☟ INFO & SPECS
  • Information:
  • Specifications:
 ☟ INFO & SPECS
  • Information:
  • Specifications:
CPU ✦ Intel i5 6500
HDD ✦ WD Blue 1TB
The Wraith Spire is a decent cooler, even for light OC. So indeed, it makes sense that you stay with the stock cooler. You could always upgrade further down the line :-)
There's less flexibility when segregating the budget for each component. What's your total budget?
Are you replacing the stock cooler for aesthetics? Have you tried oc'ing with it yet?
ill stay with the stock cooler. i just wanna know the best black fans of 12.50 max per fan
 ☟ INFO & SPECS
  • Information:
  • Specifications:
 ☟ INFO & SPECS
  • Information:
  • Specifications:
CPU ✦ Intel i5 6500
HDD ✦ WD Blue 1TB
The stock case fans should be enough already. If you want quieter fans, PW2's are good: https://tweakers.net/pricewatch/468845/be-quiet!-pure-wings-2-pwm-140mm.html
Where did you find SW2's for €12.50? That's a better deal.
If you want a bit more performance,
Apache: https://tweakers.net/pricewatch/254649/akasa-apache-12cm-zwart-120mm.html
Slipstream: https://tweakers.net/pricewatch/173696/scythe-slip-stream-1200rpm-120mm.html
Also available at higher rpm: https://tweakers.net/pricewatch/447051/scythe-slip-stream-120-db-1600-rpm.html
huh i never sayd i got sw2's for 12.50 or whatever they might be xD i sayd that was the max i want to spend on fans
 ☟ INFO & SPECS
  • Information:
  • Specifications:
 ☟ INFO & SPECS
  • Information:
  • Specifications:
CPU ✦ Intel i5 6500
HDD ✦ WD Blue 1TB
You mentioned SW2's in the OP.
well as i explained i didnt mean that
 ☟ INFO & SPECS
  • Information:
  • Specifications:
 ☟ INFO & SPECS
  • Information:
  • Specifications:
CPU ✦ Intel i5 6500
HDD ✦ WD Blue 1TB
