I am planning on purchasing a Lenovo Yoga 730, but I am between two models, the only difference being the processors. One has an "8th Generation Intel® Core™ i5-8250U Processor (1.60GHz, up to 3.40GHz with Turbo Boost, 6MB Cache)" and the other has an "8th Generation Intel® Core™ i7-8550U Processor (1.80GHz, up to 4.0GHz with Turbo Boost, 8MB Cache)".
The both models are currently the same price on Lenovo's site, but I can purchase the i5 model for $100 less than listed($1050), so is the $100 more for the i7 version worth it?
https://www3.lenovo.com/us/en/laptops/yoga/700-series/Yoga-730-15/p/88YG7000965
https://linustechtips.com/topic/938597-difference-between-cpus-in-laptop/
Only difference is higher frequency and more cache. If you need a little extra CPU performance, sure. Otherwise it's not needed.
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
It depends on what you want to do with it
Personal Desktop":
Luna, the temporary Desktop:
Both have 4 cores, 8 threads, the same graphics, the same TDP etc. The basic difference it the core and boost clock and the cache.
So, whether or not the $ 100 premium is worth is boils down to what you are using your laptop for... If you can tell us that, we can advise you the most suitable CPU.
@Christophe Corazza I will be using it for college but I may do some light gaming on it(the pc does come with a gtx 1050). And if the i7 would significantly affect multitasking that would be worth it to me to upgrade it. Thanks.
For multitasking it is beneficial to have more cores. Well, actually, threads, in the case of hyperthreading. That's because the applications can each run on different threads. It's still good to have fast, efficient cores, but for having many applications running at once, you will very much appreciate having a 4+ core CPU. So, both will perform about equal.
What software are you using for college?
@Christophe Corazza I am not completely sure as I will be a freshman this coming fall, but I shouldn't be using anything too intensive. I will probably just go with the i5 version. Thanks for the help!
The i5 verison is perfectly fine. Although expect some performance loss in some CPU intensive games as this ain't a desktop CPU. However, a mobile i5 is good enough though for 1080p 60 FPS (and maybe even 4K). With 4 cores and 8 threads it should run just about anything… as long as it is paired with a dedicated GPU like the 1050.
As for college work, since you are not using intensive (mathematical/simulation) software, the i5 will suit you very well.
But to conclude this answer I'll say this: yes it will game, yes there are faster mobile processors out there. So will you be happy with this processor? Yes. Since it has capable cooling, and has a dedicated GPU you'll be able to use it for collage and it will play games at least for the next few years to some.
Good luck with your studies! :)
8550U isn't worth it unless you need single core performance and 2MB more cache. 8250U is enough
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
