Hi I recently bought a prebuilt pc from CUK (Computer Upgrade King) for mainly gaming and it works but I have been looking into upgrading my CPU and Motherboard. I thought that if I looked up my motherboard it would give me some more information that would help me with purchasing another motherboard and CPU without having to be to confused on the compatibly issues of all my hardware, but when I searched up my motherboard nothing really helpful showed up, only other desktops with the same name. I was wondering if anyone could give me some information on it or give me other information that will help me find what I am looking for. It is called an Acer Aspire TC-780A (KBL). Anyone that replies thank you so much for the help and I'm sorry if this isnt the right place to talk about this, I'm new to using forums and heard this is a good place for any help.
Here are the components in my PC if you would like to know.
-Intel Pentium G4400 (CPU)
-8GB DDR4 RAM
-ZOTAC GeForce GTX 1050 2GB Mini
-12 in Sata to Molex LP4 Power Cable Adapter
1-8 in Angled SATA Cables
-USB 3.0 Female to USB 2.0 Male Adapter
https://linustechtips.com/topic/938318-help-a-pc-noob-out/
-8GB DDR4 RAM
Whats the wattage on the power supply? And have you really noticed any lag or low fps to really warrant a CPU and/or motherboard swap?
Edit: I can't find your specific PC. Also, you likely won't need to swap the motherboard. You can buy a CPU with the same socket type as your current CPU, and you could get a better CPU cooler as well.
Primary PC: - https://pcpartpicker.com/list/8G3tXv (Windows 10 Home)
HTPC: - https://pcpartpicker.com/list/KdBb4n (Windows 10 Home)
Server: Dell Precision T7500 - Dual Xeon X5660's, 44GB ECC DDR3, Dell Nvidia GTX 645 (Windows Server 2019 Standard)
*SLI Rig* - i7-920, MSI-X58 Platinum SLI, 12GB DDR3, Dual EVGA GTX 260 Core 216 in SLI - https://pcpartpicker.com/list/GHw6vW (Windows 7 Pro)
HP DC7900 - Core 2 Duo E8400, 4GB DDR2, Nvidia GeForce 8600 GT (Windows Vista)
Compaq Presario 5000 - Pentium 4 1.7Ghz, 1.7GB SDR, PowerColor Radeon 9600 Pro (Windows XP x86 Pro)
Compaq Presario 8772 - Pentium MMX 200Mhz, 48MB PC66, 6GB Quantum HDD, "8GB" HP SATA SSD adapted to IDE (Windows 98 SE)
Asus M32AD - Intel i3-4170, 8GB DDR3, 250GB Seagate 2.5" HDD (converting to SSD soon), EVGA GeForce GTS 250, OEM 350W PSU (Windows 10 Core)
*Haswell Tower* https://pcpartpicker.com/list/3vw6vW (Windows 10 Home)
*ITX Box* - https://pcpartpicker.com/list/r36s6R (Windows 10 Education)
Dell Dimension XPS B800 - Pentium 3 800Mhz, RDRAM
In progress projects:
*Skylake Tower* - Pentium G4400, Asus H110
*Trash Can* - AMD A4-6300
*GPU Test Bench*
*Pfsense router* - Pentium G3220, Asrock H97m Pro A4, 4GB DDR3
https://linustechtips.com/topic/938318-help-a-pc-noob-out/#findComment-11448308
It is 300W and I experience frame drop down to 40 on overwatch and used to get down to 40 also when playing Fortnite but I did everything in a Panjno video on youtube (idk if you've heard of him) and i go down to high 50s but no lower.
https://linustechtips.com/topic/938318-help-a-pc-noob-out/#findComment-11448314
What settings are you running? On a GTX 960 and a dual core i3 I managed 60 fps, rock solid, on max settings @ 1080p in Overwatch. I've never played Fortnite as I strongly dislike that genre
*GPU Test Bench*
https://linustechtips.com/topic/938318-help-a-pc-noob-out/#findComment-11448317
Acer uses custom OEM motherboards so if you be limited on cpu choices. But since you are upgrading the CPU and motherboard, all you really need to know is how many watts the PSU has and what type of RAM it has. So that pc you have is LGA 1151 socket, of the Skylake family. That CPU is pretty limiting since it is a dual core and multiplayer games will suffer.
https://linustechtips.com/topic/938318-help-a-pc-noob-out/#findComment-11448320
1 minute ago, Wazy said:
All lowest as possible on both games for the best FPS.
Especially with that GPU, I'd think you could run at least medium at 60fps
*GPU Test Bench*
https://linustechtips.com/topic/938318-help-a-pc-noob-out/#findComment-11448321
He doesn't NEED to swap the motherboard. As long as it has all the ports he needs, and he doesn't plan on Overclocking, then he just needs to pick out any old LGA 1151 CPU
*GPU Test Bench*
https://linustechtips.com/topic/938318-help-a-pc-noob-out/#findComment-11448322
That last reply was actually very helpful so would an Intel i5 6500 work?
https://linustechtips.com/topic/938318-help-a-pc-noob-out/#findComment-11448328
They were asking for help to purchase another motherboard and CPU. That and it's an OEM board so it might have less power phases that might not support a better CPU.
https://linustechtips.com/topic/938318-help-a-pc-noob-out/#findComment-11448329
That will work, it is an LGA 1151.
I've swapped hungrier CPUs into OEM boards before. They performed just as good as in an aftermarket board. There are other models of his PC that have newer i5s and i7s, I'd assume they have the same board if they're the same model. I doubt he would need a new motherboard. Not to mention, he said he's new to this, so avoiding more complex swaps would make it easier for him.
*GPU Test Bench*
https://linustechtips.com/topic/938318-help-a-pc-noob-out/#findComment-11448334
Yep.
Any intel 6th gen should be a drop-in upgrade with that motherboard.
7th gen is compatible with the socket, but it's unlikely that your motherboard got the necessary BIOS update, and I wouldn't risk it anyway because 7th gen isn't that different than 6th.
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/938318-help-a-pc-noob-out/#findComment-11448335
6 minutes ago, RadiatingLight said:
Yep.
Cool and thank you very much.
https://linustechtips.com/topic/938318-help-a-pc-noob-out/#findComment-11448343
I would suggest you to buy an H110 $30 motherboard(in case there is space for a microatx in the case). That HP motherboard will have compatibility issues later on. Then you can upgrade the bios and for $10-20 more upgrade to a G4560 or for $60-70 more get an i5 of 7th Gen.
Once you get the new motherboard, upgrade the bios. You could also ask the seller to do that. They do that for free most of the times. Then you can sell your G4400 and maybe the motherboard(there must be someone who needs OEM parts as I have seen them selling on ebay).
The 300W Power supply would work with a G4560 which is better than G4400 but maybe not with an i5 or i7 as you already have a GT 1050. So Buy a 450-550W. Don't spend too much. You don't need that much.
Main system (Mini itx 80mm)
i5-7500 | Asrock h110m | Noctua L9i | Realan H80 Case | 8GB 2400 Ram ADATA | M600 SSD | 500 GB Seagate
Other System (Laptop)
i7 3632QM | Toshiba | 8GB Corsair VS RAM | Sandisk SSD PLUS | 500GB Toshiba HDD
https://linustechtips.com/topic/938318-help-a-pc-noob-out/#findComment-11448867
