Overheating
Go to solution Solved by xAcid9,
Cap the game at 60fps or turn on Vsync, doubt you need more than that.
Hi Guys, so I am started playing Jurrasic World and my 1080ti is hitting 80c.
I play on an ultra wide but this seems really hot for I would say it not a very taxing game.
Any ideas?
CPU - i7 8700K / Motherboard - ROG Strix Z370 E/ RAM - 32GB Cosair Vengeance DDR / GPU  - GTX 1080ti - EVGA FTW3 / PSU - Seasonic Snow Silent 750W / Cooling - Cryorig H7 Monitor - Acer X34 Predator / Sound - Corsair Void - Case - Meshify C
https://linustechtips.com/topic/937977-overheating/
1 minute ago, Computernaut said:
If it's a founders edition then that's normal.
Its a FTW3.
https://linustechtips.com/topic/937977-overheating/#findComment-11445561
9 minutes ago, Nosfy said:
Its a FTW3.
What's your case?
Oh Mesh C
Your GPU is probably just targeting 80C, put your fan speed to 100% if you want lower temps
https://linustechtips.com/topic/937977-overheating/#findComment-11445575
16 minutes ago, Nosfy said:
Its a FTW3.
Try setting a slightly more aggressive fan curve.
https://linustechtips.com/topic/937977-overheating/#findComment-11445588
13 minutes ago, Streetguru said:
What's your case?
Oh Mesh C
Use the aggressive fan curve in the software. It is loud, but usually works wonders.
"The only thing that matters right now is that you're here, and you're safe."
https://linustechtips.com/topic/937977-overheating/#findComment-11445607
80°C is totally fine even over very long periods of time.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/937977-overheating/#findComment-11445625
Their really should be a sticky for gpu Temps lol
Firestrike
i7-8700k @5.0GHz w/ 1.30v, Corsair h100iv2, Gigabye Aorus gaming 7, 16GB(8x2) 2666MHz ddr4, Dual RX470's OC'd to 1390mhz(atm) in corssfire - liguid cooled with corsair h60's, 3.25 TB in Samsung SSD's, anidees white crystal cube case
Retired:
i5-4440k @3.2GHz, gigabyte ga-z87x-ud5h z87, 24GB DDR3, 3x1TB Seagate Baracuda HDD.
https://linustechtips.com/topic/937977-overheating/#findComment-11445922
Turn up fans. Poor airflow makes open air coolers perform bad. Especially with default fan profiles.
https://linustechtips.com/topic/937977-overheating/#findComment-11446017
https://linustechtips.com/topic/937977-overheating/#findComment-11446398
On 6/15/2018 at 10:22 PM, Streetguru said:
What's your case?
Oh Mesh C
What do you mean its targeting 80c?
https://linustechtips.com/topic/937977-overheating/#findComment-11450387
I know, its just one of those things I guess.
To be honest I do not like my cards running hotter than like 70c so when I get 80c i get nervous even tho I know its fine.
https://linustechtips.com/topic/937977-overheating/#findComment-11450390
It lets it run at 80c for lower fan noise.
https://linustechtips.com/topic/937977-overheating/#findComment-11450594
Got ya.
https://linustechtips.com/topic/937977-overheating/#findComment-11452689
