PC Getting cooler after removing side panel?
GeneralOxxy
So some people said that removing the side panel from the computer case will give me cooler temps is it true?
Thanks in advance!
Yes, because you have more space for hot air to escape.
Desktop benching:
Thanks!
3 minutes ago, GeneralOxxy said:
Thanks!
it will draw in more dust, that's why we usually dont do this for long term use.
Desktop benching:
Dust isnt a problem because i clean my pc every month and can i just keep it open while im gaming? When im idle my cpu is 50 c and in load 65 gpu 47 idle and 70 load
yeah
this image depicts perfectly my pc 10 yrs ago trying to play battlefield 2 online
ASUS X470-PRO • R7 1700 4GHz • Corsair H110i GT P/P • 2x MSI RX 480 8G • Corsair DP 2x8 @3466 • EVGA 750 G2 • Corsair 730T • Crucial MX500 250GB • WD 4TB
yes, but I dont think your parts need more cooling than it already has.
Desktop benching:
Those temps are fine if you have anything else than FX series AMD CPU. If you have FX, 65C load temp is too hot and you need to look into getting better CPU cooler or changing thermal paste.
Also removing side panel only really helps if case has very restrictive airflow or no intake fans.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
i have 2 intake fans and an i3
Those temperatures are perfectly fine. In your situation, there is no need to increase airflow by taking off your side panel.
Creating a higher pressure inside your case than outside (by blowing more air in than sucking air out), you can minimise dust buildup. So you're fine here as well. :)
2 fans means nothing if you have restrictive case like Enthoo P400 for example. Otherwise everything is good already. Your temps are well under danger levels.
Completely agree. However, OP’s temps prove that he is not suffering from a restricted air flow.
