I'm a new member and this is my first post. I'm 42 and am somewhat ashamed that I have never attempted a pc build before. I've always been a console gamer. My kids have started to take over the PS4's, so I figured it's time to move to a pc.
I only have a single 1080p monitor for now, but I plan to add a 1440p soon. I also already have a mouse, keyboard, and speakers. I don't have a specific budget in mind, but somewhere around the price of the parts list I am posting. I don't really care about RGB, but I added some Halo's at the request of my wife. I also only wanted RGB that would work with Aura. Let me know how it looks and any suggestions you may have. Thank you.
https://pcpartpicker.com/list/gH7h7W
https://linustechtips.com/topic/936759-my-first-build/
change your cpu cooler, that is an over priced waste, get a https://smile.amazon.com/dp/B01KVNCEIG/?tag=pcpapi-20&th=1
motherboard, well if your down to switch to a ryzen 7 1800X its cheaper and better speed, and u can get an asus prime b350 plus for a lot cheaper
otherwise it all looks great :)
If my Response helped you, Please click the Check under my reply, to mark it as The Solution!
https://linustechtips.com/topic/936759-my-first-build/#findComment-11434327
5
https://smile.amazon.com/dp/B00XJMQDUM/ref=twister_B06ZZ1T1KL?_encoding=UTF8&psc=1 this would be a closer competitor to the noctua cooler
https://linustechtips.com/topic/936759-my-first-build/#findComment-11434340
1. The cooler is amazing for quiet operation. If you want something from bequiet grab a dark rock pro 4.
2. 1800x is not faster with the exception of productivity and streaming. 2700x is very close to the 8700k, but is beaten out in singlethreaded games and trade blows in heavily multithreaded games. It beats the 8700k im productivity.
3. Dont pair a 1800x with a b350 board. X370 and a 1700 or X470 and a 2700 is a more balanced buy for future upgrades. At essentially no performance loss
https://linustechtips.com/topic/936759-my-first-build/#findComment-11434346
15 minutes ago, gmentals said:
Should buy a better overall value system instead and use the money saved to get a better display
Shouldn't need all of the extra fans, if you want RGB stuff here ya go I guess
PCPartPicker part list: https://pcpartpicker.com/list/4NPWcY
Price breakdown by merchant: https://pcpartpicker.com/list/4NPWcY/by_merchant/
CPU: AMD - Ryzen 5 2600 3.4GHz 6-Core Processor  ($189.99 @ Amazon)
CPU Cooler: Cooler Master - MasterLiquid ML240L RGB 66.7 CFM Liquid CPU Cooler  ($59.99 @ Amazon)
Motherboard: MSI - X470 GAMING PLUS ATX AM4 Motherboard  ($129.99 @ B&H)
Memory: Team - Vulcan 16GB (2 x 8GB) DDR4-3000 Memory  ($154.99 @ Newegg)
Storage: Western Digital - Blue 250GB M.2-2280 Solid State Drive  ($69.99 @ Amazon)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($59.09 @ OutletPC)
Video Card: Gigabyte - GeForce GTX 1070 Ti 8GB Video Card  ($459.00 @ Newegg)
Case: Cooler Master - MasterCase H500P Mesh White ATX Mid Tower Case  ($159.98 @ Newegg)
Power Supply: SeaSonic - FOCUS Gold 750W 80+ Gold Certified Semi-Modular ATX Power Supply  ($80.24 @ Amazon)
Total: $1363.26
Generated by PCPartPicker 2018-06-12 03:45 EDT-0400
Going to want to use StoreMI with X470
https://linustechtips.com/topic/936759-my-first-build/#findComment-11434356
and that is still, a lot more expensive, while looking nice it wont be much diffrent then the 120W one i showed
i use the one i showed and it works great
https://linustechtips.com/topic/936759-my-first-build/#findComment-11434358
i have a 1800X and b350 plus, they work perfect together
https://linustechtips.com/topic/936759-my-first-build/#findComment-11434363
actually, there would be a big performance difference. http://www.guru3d.com/articles_pages/be_quiet_pure_rock_slim_cpu_cooler_review,7.html
index.php?ct=articles&action=file&id=25851
https://linustechtips.com/topic/936759-my-first-build/#findComment-11434368
Like there is nothing wrong with the combo. It is just wiser to get a 1700 since it can be overclocked to a 1800x and then a X370 or X470 board (like the fatality board from ASrock).
The newer boards are better suited for OC and not to mention newer CPUs in the future.
https://linustechtips.com/topic/936759-my-first-build/#findComment-11434373
it will work fine with new cpus
https://linustechtips.com/topic/936759-my-first-build/#findComment-11434380
True, but you dont want bad VRMs powering future CPUs. B350 boards are in general bad overclockers.
X470 also comes with features such as Store MI and precision boost 2 and XFR2 to utilize future CPUs without needing a overclock, while performing better in singlethreaded games.
Lets not diverge from the topic at hand
@gmentals your build looks fine. Add an 3TB HDD from seagate for mass-storage. If this is a pure gaming build there is very little i would change.
https://linustechtips.com/topic/936759-my-first-build/#findComment-11434390
yeah but i dont overclock
the pciis a beast and handles anything i want it for, so overclocking isnt needed
im sick of people like you jumping in hey do this! right after i start helping someone, so it seems im done here
https://linustechtips.com/topic/936759-my-first-build/#findComment-11434872
19 minutes ago, LamoidZombieDog said:
-snip-
You do you. I will recommend what ive found out to be the better choices. Dont go around thinking people wont contradict what you are suggesting. There are a lot of those hanging around this side of the forums including me.
And yes i think we are done here.
https://linustechtips.com/topic/936759-my-first-build/#findComment-11434919
Total: $1363.26
I was considering Cooler Master, as their RGB works with Aura. I don't want a white case though. I could wait a few weeks for the H500M. I also like the Phanteks Evolv X, but it won't be available until August. I'm also not sure about AIO's, but I am considering them.
Everything I've read suggests that it is a solid cooler. It is pricey, but I plan to overclock. It seems that most adequate air coolers are in the same price range. I would prefer to stick with Intel. I had a few AMD based laptops in the past and was never impressed. All 3 of them have failed. I do realize that they are much more competitive now, but I want to try Intel.
13 hours ago, GoldenLag said:
Add an 1-4 TB HDD for mass storage. 500GB doesnt last very long. Are you only planning on using it as a gaming rig or do you plan on doing some productivity like streaming, video-editing etc?
Other than that it looks good
I forgot to list a 1TB drive that I already have. This will be primarily for gaming, web browsing, and lite photo editing.
https://linustechtips.com/topic/936759-my-first-build/#findComment-11436562
>obviously intends to overclock 8700k because of the z370 and noctua cooler
>you recommend a cheap cooler
https://linustechtips.com/topic/936759-my-first-build/#findComment-11436637
24 minutes ago, LoganTNZ said:
If youre going to be gaming at 1440p, get a ryzen 2600 and use the money to buy a 1080ti instead
i could get the 1080ti anyway, but I don't think it's worth the current pricing. I would still want an Asus, so about $820. By the time I get a 1440p, new gpu's will be out.
https://linustechtips.com/topic/936759-my-first-build/#findComment-11436742
I mean you could buy a better monitor right now with the build I posted and be perfectly fine for 1440p 144hz gaming or light 4k 60hz gaming.
https://linustechtips.com/topic/936759-my-first-build/#findComment-11436743
I have no interest in AMD, but I appreciate your suggestion. It's not that I don't have the money, I could by one now. I just want to start with the monitor I have to see if I even like PC gaming.
https://linustechtips.com/topic/936759-my-first-build/#findComment-11436766
If you're not sure why don't you just spend like $400 on an APU system to get you started? Will do 1080p pretty alright.
https://linustechtips.com/topic/936759-my-first-build/#findComment-11437000
No problem.
If you were doing streaming or videoediting or even heavy photo editing i would grab a 2700x, but for your workload and lean towards gaming a 8700k will work just fine.
https://linustechtips.com/topic/936759-my-first-build/#findComment-11437402
17 hours ago, GoldenLag said:
No problem.
Thanks. That is basically what I have read. I probably don't even need a 8700K, but f#$k it.
https://linustechtips.com/topic/936759-my-first-build/#findComment-11439910
