I had an external hard drive that I wanted to get off my desk. I took it out of the enclosure and made it internal.
But now when I go into disk management, it asks me to initialize the disk every time and the entire HDD shows up as unallocated.
Is there any way to fix this problem? It's not a huge problem since I have the data backed up elsewhere, but I'd like to get the data back if possible.
https://linustechtips.com/topic/935182-problem-turning-external-hdd-into-internal/
1 hour ago, Some Random Member said:
Can you put it back into tge enclosure? Then if it is in the enclosure do a data recovery.
There is a reason external hdd's are cheaper, most of them even have some weird proprietary connectors so you couldn't use them internally.
literally every external drive enclosure I've opened up had a normal SATA HDD inside, with an adapter cable/circuit board plugged into it's SATA connectors to connect the external power and data ports.
OP - I agree just format the drive completely and start from scratch - I've used several HDD's that were originally sold as external USB drives as internal over the years. If you format it from scratch it will work exactly as you want it to.
HEDT: i9 10980XE @ 4.9 gHz, 64GB @ 3600mHz CL14 G.Skill Trident-Z DDR4, 2x Nvidia Titan RTX NVLink SLI, Corsair AX1600i, Samsung 960 Pro 2TB OS/apps, Samsung 850 EVO 4TB media, LG 38GL950G-B monitor, Drop CTRL keyboard, Decus Respec mouse
Laptop: Razer Blade Pro 2019 9750H model, 32GB @ 3200mHz CL18 G.Skill Ripjaws DDR4, 2x Samsung 960 Pro 1TB RAID0, repasted with Thermal Grizzly Kryonaut
Gaming Rig: i9 9900ks @ 5.2ghz, 32GB @ 4000mHz CL17 G.Skill Trident-Z DDR4, EVGA RTX 2080 Ti Kingpin, Corsair HX1200, Samsung 970 EVO Plus 2TB, Asus PG348Q monitor, Corsair K70 LUX RGB keyboard, Corsair Ironclaw mouse
HTPC: i7 7700 (delidded + LM), 16GB @ 2666mHz CL15 Corsair Vengeance LPX DDR4, MSI Geforce GTX 1070 Gaming X, Corsair SFX 600, Samsung 850 Pro 512gb, Samsung Q55R TV, Filco Majestouch Convertible 2 TKL keyboard, Logitech G403 wireless mouse
