Need help with a proper internet connection
Solved by factorialandha,
Just now, Lawrence196 said:Thankyou, this could work, but my family likes to use the apple airdrop router which isnt real good, could i run an extra router?
you can wire as many routers in as you have network ports on the comcast device for the most part, but you are limited to the throughput of the switch on the comcast device for that method it makes for a very disjointed network and makes communication between devices between those access points a little problematic, but if you dont care about that, id look at decent "whole home" wireless systems maybe, some of them have good reviews and apparently work well. But can be expensive, so its all down to how much you want to spend
