Do you have anymore monitors/ports you can test on the GPU?
Personal Computer Build:
CPU: i7-4790k | Motherboard: Asus Z97-A | RAM: 16GB G. Skill | Graphics Card: Nvidia Geforce Gtx 1070 TI Founders Edition | Case: Corsair 750D | Storage: Samsung 850 Evo 250GB / Western Digital Black 1TB / Western Digital Blue 1TB | Power Supply: EVGA 750watt SuperNova Gold Rated | Displays: 3 VG248QE 24" 144hz, 1MS | CPU Cooler: Corsair H100i V2 | Keyboard: Razer Chroma BlackWidow
https://linustechtips.com/topic/934379-please-help/#findComment-11412213
14 minutes ago, ASTRIXgaming45 said:
Hey Guys, Aus.........trix Here
I'm Here Seeking Help And Information.
I Have recently Built My New Gaming/3D Modeling Desktop https://pcpartpicker.com/list/WRHNzY
After Completing The Build I Have Gone To Start The PC And To My Supprise I See Nothing On My Monitor Nothing At All, So I Did The Obvious And Checked That My HDMI Was Pluged In Both PC (GPU) And Monitor (Yes It Was On). So Then I Went Over My Connections And All Are Connected PSU And MOBO (They Were) Then I Checked My Ram But They Were In The Right Dims.I Am Not Receiving Any MOBO Beep Codes,Please Any Help Or Information Would Be Greatly Apriciated.
PC PART PICKER SPECS HERE https://pcpartpicker.com/list/WRHNzY
Did you update the BIOS?
In search of the future, new tech, and exploring the universe! All under the cover of anonymity!
https://linustechtips.com/topic/934379-please-help/#findComment-11412229
your list does not include a monitor so i'm assuming you already own one, do you have a different computer you can test the monitor with?
Also some pics so we can check for anything would be helpful
Insanity is not the absence of sanity, but the willingness to ignore it for a purpose. Chaos is the result of this choice. I relish in both.
https://linustechtips.com/topic/934379-please-help/#findComment-11412241
I can't
The B350 chipset was made for the AMD Ryzen 1000 series CPUs, therefore you need a BIOS update before you can insert your CPU. in which case you may want to buy a disposable CPU, to use to install the BIOS.
https://linustechtips.com/topic/934379-please-help/#findComment-11412251
Don't you just hate it when the OP just deletes the original post so new viewers have zero context as to what is going on?
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/934379-please-help/#findComment-11412320
