Hey Guys ,
                  Today I bought a used i7 870 replacing my old i3 530 .I swapped the CPU and applied thermal paste and screwed in the stock cooler. The problem is that it is overheating while gaming.At ideal the temp varies from 45-50°c and while playing AC origins it went up to 94° and most of the time below 90°.the sound of the cooler is so annoying when it gets high temp.Is this safe or will something bad happen? I don't have the money to buy a cooler now . What should I do ? Is it going to be alright ?? Plz help .
https://linustechtips.com/topic/934104-i7-870-overheating/
Well you went from a 73w TDP processor to a 95w TDP processor so it sounds like your stock cooler just cant dissipate the heat well enough for that cpu. I think that cpu has a max temp of 100c although staying at that high of a temp can cause a processor to prematurely die. I would suggest getting a better cooler if possible.
https://linustechtips.com/topic/934104-i7-870-overheating/#findComment-11409521
23 minutes ago, Amal Dev said:
Hey Guys ,
I switched from an i5-750 to X3470, which I believe is the same as the 870. It runs fine and does not get hotter than 80 degrees under the stock OEM cooler of the 750, which looks like a normal Intel one (it does like to make noise at full load). What model of cooler are you using?
https://linustechtips.com/topic/934104-i7-870-overheating/#findComment-11409561
12 minutes ago, Dewen said:
Should be the stock cooler which is not build for cooling that CPU while gaming.
Replace the CPU-cooler and everything should be fine.
Also make sure to remove any dust in your case.
Don't have the money to buy the cooler now.
https://linustechtips.com/topic/934104-i7-870-overheating/#findComment-11409564
Don't have the money now for a cooler
https://linustechtips.com/topic/934104-i7-870-overheating/#findComment-11409583
xeons tend to run cooler than core iX :)
https://linustechtips.com/topic/934104-i7-870-overheating/#findComment-11409589
The X3470 and the i7-870 are both 4c/8t CPU's which both have a TDP of 95W and both are clocked at 2,93 GHz with a boost up to 3,6 GHz... Except for the memory support on the Xeon I would even say these processors are identical.
This is not a Xeon-Ex-xxxxL processor... How would the Xeon run cooler than it's Core equivalent?
https://linustechtips.com/topic/934104-i7-870-overheating/#findComment-11409642
binning, sillicone lottery
https://linustechtips.com/topic/934104-i7-870-overheating/#findComment-11409650
What kind of cooler do you have right now? and how is the airflow in your case? Maybe just upgrading the CPU fan on the existing heatsink, or mounting an outtake fan would be plenty to cool your i7.
https://linustechtips.com/topic/934104-i7-870-overheating/#findComment-11409653
I'm assuming it's the i3 stock cooler (which is weaker than the i7 one he SHOULD have.
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
https://linustechtips.com/topic/934104-i7-870-overheating/#findComment-11409664
I would expect that, but I have no idea which model of heatsink his PC has. If it is big enough heatsink upgrading the fan might actually work.
This cooler is far from being a quality cooler, but seems to manage fine, for me:
pol_pl_COOLER-AVC-socket-1155-1156-1489_
https://linustechtips.com/topic/934104-i7-870-overheating/#findComment-11409677
My cooler is not that same intel stock cooler...it has more heatsink than the intel stock cooler but my CPU gets about 90° everyone on load.
make sure it's mounted properly and the fan is running well, save up for a cooler in the meantime(used or new doesn't matter as long as it's better).
https://linustechtips.com/topic/934104-i7-870-overheating/#findComment-11409769
37 minutes ago, Pyramiden said:
I had no idea that would actually make a significant difference. It would be interesting to see a thorough test.
yeah, the difference  in xeons vs some i7 is that they are picked as the coolest and best performing, they might require less voltage to keep the same clock so they run cooler , simple
https://linustechtips.com/topic/934104-i7-870-overheating/#findComment-11409790
