Need Help Deciding Between 2 Displays
Go to solution Solved by sazrocks,
That dell monitor is great; in fact I'm typing this on it right now. Great pixel density, and g-sync is awesome
I am upgrading my display this summer in the next few weeks, followed by a large PC upgrade. I am prepared to spend money, but i am spending a lot so I would like to save where possible.
Essentially the two displays I want are:
1. (393$) Dell Gaming Monitor S2417DG YNY1D
- 1440p
- 165hz
- G-Sync
- 3 year warranty
2. (299$) AOC AGON AG241QX 23.8” Gaming Monitor
- 1440p
- 144hz
- FreeSync
- 1 year warranty
I have an Nvidia GPU and plan on sticking with it for the foreseeable future. I am wondering if it is worth the extra money, given that I am looking to save money where I can. I am not opposed to spending the extra, just want to make sure it would be worth.
Main Rig | Personal Build | Windows 10 | R7 2700x 3.7~4.3ghz | ASUS ROG Strix B450-I | 16gb DDR4 3200mhz | GTX 1080 FE | Coolermaster Elite 130 | Corsair H60 | WD Blue SN500 500GB NVMe SSD + 1tb WD Green HDD + 1tb WD Blue HDD
Laptop | HP m6-w102dx | Windows 10 | i7-5500u 2.4~3.0ghz | 8gb DDR3L | GT 930m 2gb| 120gb Sandisk SSD
Phone | Pixel 3 | Verizon | 64gb
https://linustechtips.com/topic/934035-need-help-deciding-between-2-displays/
Current LTT F@H Rank: 24    Score: 10,097,484,643   Stats
Yes, I have 9 monitors.
My main PC:
OS: Windows 11
CPU: Ryzen 9 9950X
Cooler: Noctua NH-D15
Mobo: Asus ProArt X670E Creator WiFi
RAM: 96GB Trident Z Neo @6400 CL32
GPU: RTX 4090 Founders Edition, Radeon Pro WX 5100
PSU: Corsair RM1000e
SSDs: Samsung 990 Pro 4TB NVME, Samsung 970 evo plus 1TB NVME, 2x Samsung 870 evo 2TB, Samsung 860 evo 1TB, Samsung 970 evo 500GB NVME
Case: Fractal Design Define R5 Black w/ Tempered Glass Side Panel Upgrade
Monitors: 9 Monitors: Alienware AW3423DWF 3440x1440@165Hz, Acer H236HLbid 1080p@77Hz, HP D7z72AA 1080p@60Hz, Dell Inspiron 24 3459 1080p@60Hz(used only as display), Dell U2724D 1440p@120Hz, ASUS VP228 1080p@60Hz, 2x HP ZR2440W 1200p@60Hz
unRAID server (Plex, Backups, NAS, Duplicati, game servers):
OS: unRAID 7.1.4
CPU: Ryzen R9 3900X
Cooler: Noctua NH-U9S
Mobo: Asus ROG Strix X470-F
RAM: 64GB G-Skill Ripjaws V @ 3200MHz
PSU: EVGA G3 850W
Total Storage: Raw: 94TB, Usable: 64TB
SSD: Samsung 990 Pro 2TB NVME, Teamgroup 4TB NVME
HDDs: 4x HGST Dekstar NAS 4TB @ 7200RPM (3 data, 1 parity) + (7x Seagate Ironwolf NAS 8TB + 2x Toshiba N300 NAS 8TB in ZFS)
Case: Fractal Define 7 XL
Other: Added 3x Noctua NF-F12 intake, 2x Noctua NF-A8 exhaust, Inatek 5 port USB 3.0 expansion card with usb 3.0 front panel header
- 1440p
- 165hz
- G-Sync
- 3 year warranty
- 1440p
- 144hz
- FreeSync
- 1 year warranty
if Gsync is important to you get the gsync one. BUT also note the AOC as better contrast but the stand is inferior. ALSO note the 3 year warranty on the dell
https://www.newegg.com/Product/Product.aspx?Item=0JC-0004-00551&ignorebbr=1&nm_mc=KNC-GoogleAdwords-PC&cm_mmc=KNC-GoogleAdwords-PC-_-pla-_-Monitors+-+LCD+Flat+Panel-_-0JC-0004-00551&gclid=CjwKCAjwo87YBRBgEiwAI1LkqcrDyG1R-MEvIkJ0vSFjqphXUMi3_A4yt096DIdDd68lclcyel6yRxoCWmsQAvD_BwE&gclsrc=aw.ds
save $7 here
EDIT the AOC also has speakers
8 hours ago, Senzelian said:
G-Sync is a major advantage and I'd pay those additional $100 for it.
And the 3 year warranty is nice to have too!
8 hours ago, wojtepanik said:
go for dell!
well thank you all for the help. the consensus seems to be to go for the Dell, so ill just wait for an extra paycheck before i buy. Thanks :D
