2 minutes ago, Sammy Toss said:
Hey Guys! What's a great white cpu cooler (rgb led or not) for a white theme build that can lower temps greatly? My processor would be an i7-8700. Or it would be better if I go liquid cooling? Thank you very much.
R1 from Croyrig or the NH-D15 from Noctua with the chromax covers will perform excellent.
http://www.cryorig.com/r1-universal_us.php
https://noctua.at/en/nh-d15
https://noctua.at/en/na-hc4-chromax-white
https://linustechtips.com/topic/931197-white-cpu-cooler/#findComment-11382918
Thank you very much for the response. I will check those links. :)
https://linustechtips.com/topic/931197-white-cpu-cooler/#findComment-11382934
Enermax makes a white ET-ST40 if I remember correctly
CPU: Core i9 12900K || CPU COOLER : Corsair H100i Pro XT || MOBO : ASUS Prime Z690 PLUS D4 || GPU: PowerColor RX 6800XT Red Dragon || RAM: 4x8GB Corsair Vengeance (3200) || SSDs: Samsung 970 Evo 250GB (Boot), Crucial P2 1TB, Crucial MX500 1TB (x2), Samsung 850 EVO 1TB || PSU: Corsair RM850 || CASE: Fractal Design Meshify C Mini || MONITOR: Acer Predator X34A (1440p 100hz), HP 27yh (1080p 60hz) || KEYBOARD: GameSir GK300 || MOUSE: Logitech G502 Hero || AUDIO: Bose QC35 II || CASE FANS : 2x Corsair ML140, 1x BeQuiet SilentWings 3 120 ||
LAPTOP: Dell XPS 15 7590
TABLET: iPad Pro
PHONE: Galaxy S9
She/they
https://linustechtips.com/topic/931197-white-cpu-cooler/#findComment-11382974
Did you mean 8700 or 8700k? Most of the coolers mentioned are overkill if you're not oc'ing.
Where are you shopping / located? What ram and case are you using?
https://linustechtips.com/topic/931197-white-cpu-cooler/#findComment-11385517
8700. I'm going to use Tforce Delta RGB 2666mhz and a h500p mesh white for the case. I'm from Philippines. Thank you very much.
https://linustechtips.com/topic/931197-white-cpu-cooler/#findComment-11388753
SE-214L: http://dynaquestpc.com/product/idcooling-se-214l-snow-white-led-cpu-cooler/
https://linustechtips.com/topic/931197-white-cpu-cooler/#findComment-11391403
5 hours ago, WoodenMarker said:
Thank you very much. I was eyeing on that before but I couldn't find reviews about it and wonder if it's good for a 30$ cooler and enough for 8700.
https://linustechtips.com/topic/931197-white-cpu-cooler/#findComment-11392411
It's slightly better than the 212 Evo and plenty of cooling if you're not oc'ing.
https://linustechtips.com/topic/931197-white-cpu-cooler/#findComment-11392575
ahhh very nice, thank you very much for that. Big help :)
https://linustechtips.com/topic/931197-white-cpu-cooler/#findComment-11392632
