New Case - Airflow, Silence & Thermal
Hello.
I built a computer 3 months ago and I always use my computer as a heater of some sort during the winter. But now that it's summer.
The room gets really hot when I wake up, despite windows open to let cool air in during the night to compensate when the sun comes
up and haunts every gamer in the world. I am wondering if I should buy a new case or change fan setup.
Computer Specs & Fan setup:
Thermal test on "idle" and gaming load:
CPUID HwMonitor Numbers with BDO Trayed
Black Desert Online running in tray at lowest settings possible
CPU or GPU not overclocked!
Case Fan 1: Push Rear 1x140mm [Noctua NF-A14 Premium Fan]
                     Min: 503 RPM     Max: 742 RPM
Case Fan #2: Pull Front 3x120mm [Noctua NF-F12 Premium Fan]
                     Min: 897/3 RPM  Max: 1085/3 RPM
Corsair H115i: Push Top 2x140mm [Noctua NF-A14 Premium Fan]
                     Min:
772 RPM     Max: 981 RPM   (Fixed at 70% RPM 960-1020 RPM in Corsair Link)
                     Water Temps/Pump RPM: 36.1 °C / /19501980 RPM
CPU Package:
                        Min: 36°C  Max: 45 °C
GPU:
                        Min: 48 °C   Max: 52 °C
                        Value: 350 RPM Min: 171 RPM Max: 1426 RPM (<- Uncertain, since the game is in tray it's not using GPU)
Black Desert Online running in preset Highest spec (normal)
                     Min: 503 RPM     Max: 742 RPM       (No change, BIOS setup)
                     Min: 897/3 RPM  Max: 1085/3 RPM  (No change, BIOS setup)
                     Min:
772 RPM     Max: 985 RPM   (Fixed at 70% RPM 960-1020 RPM in Corsair Link)
                     Water Temps/Pump RPM: 38.6 °C / /19501980 RPM
CPU Package:
                        M
in: 36  Max: 64/71 °C
GPU:
                        Min: 48 °C   Max: 66 °C
                        Value: 1416 RPM Min: 170 RPM Max: 1426 RPM
Those numbers don't look bad really for slightly above 20C ambient. I don't think fan setup hinders much, at least not relative to the popular flat-solid-panels-with-side-vents case designing. Something with more airflow-oriented panels such as Fractal Meshify C or Corsair H500P Mesh could yield lower temps but also will likely be louder.
CPU: AMD Sempron 2400+ / MOBO: Abit NF7-S2G / GPU: WinFast A180BT 64MB / RAM: Mushkin DDR333 256MBx2 / HDD: Seagate Barracuda 7200RPM 120GB
the pc will allways dump heat into the room. only thing you can really do is setupp the pc to dump that heat out the windows. (maybe place it by the window (idk)
9 minutes ago, meenmeen1103 said:
Corsair H500P
Cooler master.
My friend runs his outputs into a cloths drier vent(using an in-line fan). It's loud, but cool on hot days.
My Folding Stats - Join the fight against COVID-19 with FOLDING! - If someone has helped you out on the forum don't forget to give them a reaction to say thank you!
The only true wisdom is in knowing you know nothing. - Socrates
Please put as much effort into your question as you expect me to put into answering it.
  • CPU
    Ryzen 9 5950X
  • Motherboard
    Gigabyte Aorus GA-AX370-GAMING 5
  • RAM
    32GB DDR4 3200
  • GPU
    Inno3D 4070 Ti
  • Case
    Cooler Master - MasterCase H500P
  • Storage
    Western Digital Black 250GB, Seagate BarraCuda 1TB x2
  • PSU
    EVGA Supernova 1000w
  • Display(s)
    Lenovo L29w-30 29 Inch UltraWide Full HD, BenQ - XL2430(portrait), Dell P2311Hb(portrait)
  • Cooling
    MasterLiquid Lite 240
1 minute ago, Ben Quigley said:
Cooler master.
Oh duh! Late night, silly mistake :P
he could dump all the heat into a vat of water using a radiator and a insulated fan. wouldnt recommend it due to coorosion. and the heat will eventually end up in the room anyway
Haha we've all been there!
  • CPU
    Ryzen 9 5950X
  • Motherboard
  • RAM
    32GB DDR4 3200
  • GPU
    Inno3D 4070 Ti
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
All the test was done with dust filter in the front & front panel off and top panel on. (As well as door closed and window open)
I am currently running all panels and dust filters off, to cool my PC and radiator fans are running at 100% in Corsair Link. (The other fans are still the same)
The door is open and windows are open, the windows have the 2 Corsair 140mm fans that comes with the radiator sitting
near the window pulling and pushing air connected with the Noctua Low-Noise adapter).
The room ambient temperature I would guess is between 22-26C. I have no way to check, but the fact that I am sweating right
now. Makes me believe those numbers, even with breeze hiting me. :P
Black Desert Online is running at highest settings as mention above!
This is the temperatures I have NOW in corsair link with TOP ON: https://i.imgur.com/T3DtzV3.png
This is the temperatures I have NOW in corsair link with TOP OFF: https://i.imgur.com/RTVxF4r.png
CPU Package temp: lowest: 52  highest: 70C
Yeah slightly high hardware temps for load % but with ambient being high to start off, sensible. Looks like the top panel doesn't make a huge difference, but a different case could help as far as aesthetics of not having a front panel currently. As far as room temp, a different case nor fan setup would help. You either want to dump the heat straight out of the room like mentioned above, or promote even more airflow circulation in your room with a window and/or door open
Is adding a ceiling fan to the room an option?  Moving air feels cooler than still air, even same temp.  Or add a floor fan of some sort and blow air in from the cooler hallway or out of the room into the hallway?  How about a window A/C unit?
WIthout going ghetto like your friend, you're going to have heat in the room unless you go for a much lower performing PC.
Onyx AMD Ryzen 7 7800x3d / MSI 6900xt Gaming X Trio / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 32GB / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single
Emma : i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27" 1080p
Plex : AMD Ryzen 5 5600 - Gigabyte B550M AORUS Elite AX - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + WD Red NAS 4TBx2 - TP-Link AC1200 PCIe Wifi - EVGA SuperNova 650 P2 - ASUS Prime AP201 - Spectre 24" 1080p
Steam Deck 512GB OLED
OnePlus:
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
Answering both at the same time.
There is no way I can install a ceiling fan as the room have a light source half the
size of a normal ceiling fan and if installed. I do have a hole in one of the walls to
get somewhat fresh air in during the winter. Floor fan would push air in from nature
and a good increase of dust and things eight fold, due to the room beneath me is
basically the foundation of where the house stands on. I was thinking of buying a
A/C unit, however. My room is barely a little bit larger than a storage room ^_^.
As I mention, my only solution was the ghetto solution of using the 2x140mm fan
I got with my Corsair H115i to pull air in and/or push out. To at least cool the room
a little bit. However I would like to point out that my main goal with this post is to get
lower temps of the computer. However I do understand that the ambient temperature
of the room plays a roll aswell.
If you have any ideas on how to improve ambient room temperature without spending
a lot of money. Would love that a lot :P
