I had a bright idea, while watching techlinked, and thought about cooling every part of a computer (ram cooler, hard drive cooler,) and looked up GPU Coolers, and I’m not talking about an aftermarket shroud to put on it, but like a part similar looking to a gpu, that you can plug in to the pcie slot next to the gpu, and cools it.
Do they already make them? Am I blind?
I hAve an unfinished pc build. Pls dont bully for not having one yet or i cry.
https://linustechtips.com/topic/930420-such-thing-as-gpu-cooler/
You mean air cooling ?..like ..a fan :P
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
1 minute ago, Fruitsnacc said:
Yeah except in a separate pcie slot.
they make pcie slot fans that blow up. Like this guy. https://www.amazon.com/Titan-Adjustable-Dual-Cooler-TTC-SC07TZ/dp/B008A2TDC6
Won't really help too much though, you want a full coller.
Well, like watercool your gpu, and have this on the side. Like an extra -2 degrees Celsius.
that won't really won't. Thats what your case fans are for, and the watercooler is already touching everything that makes heat.
Yea it wont help.
if ur running a air cooler, then case fans will be all thats needed.
if your running a waterblock, then its not again its not needed as the block does the work.
