No system post after installing GTX 1070
Solved by suchamoneypit,
28 minutes ago, Jurrunio said:Maybe try taking it off and plugging it back in multiple times? Make sure you hear a click from the PCIe slot (unless it's the type that moves back and forwards.
23 minutes ago, paddy-stone said:Are you using the same cable both times? unclear whether that's the case or not?
Thank you for your suggestions.
System worked fine with a 390X, but 1070 is newer I guess. I downloaded and updated ALL motherboard apps like LAN, audio, ect. Most importantly I updated BIOS. System posts after updating BIOS and gives display through the GPU. Now windows locks up during boot, thats another issue im now trying to resolve.
