Will fps_max 0 bottleneck CPU or GPU in CS:GO?
z0neGOD
Hello guys! So lets say I have fps_max 0 on for more fps. Is there any down sides? I mean the game itself is set at max 300 fps. But does anything happen to the cpu or gpu as I mentioned. Will it decrease or increase the usage?
CS:GO is CPU limited. The GPU will scale with it until the CPU hits its max though, so both components will heat up more.
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
Do you think I should keep it on max 300fps?
There is no benefit to having more than 300fps. Maybe a few nanoseconds less input lag, but that's about it.
okay my man thankyou agian.
launch options:
-console -novid -high -threads 4 -tickrate 128 fps_max 144 (if you have a 144 hz monitor)
fps max 0 = no limit, will work fine
