Hello guys,  I've been thinking of upgrading my pc lately, especially my gpu, cpu, motherboard and psu. Want to buy the 1080ti along with 8700k. Or should I perhaps wait for the new volta architecture to come out and then decide what gpu to buy ?
Right now i have msi 970, i5 6600k, Msi Z170 gaming pro, 4x4gb DDR4 2666MHz CL15 HyperX, 620W seasonic psu. Could you guys recommend me what motherboard, psu probably new ram to buy?
Thanks. ^_^
https://linustechtips.com/topic/927204-help-me-upgrade-my-pc/
then next Nvidia architecture is Turing not Volta.
Bethesda PC:   R7 3700X  -  Asrock B550 Extreme 4  -  Corsair Dominator Platinum RGB 16GB@3.6GHz -  Zotac AMP Extreme 1080TI -  Samsung 860 Evo 256GB  -  WD Blue 2TB SSD -  500DX  -  Stock cooling lul  -  Rm650x
CrumpleBox V3:  Xeon X5680  -  Asus X58 Sabertooth  -  DDr3 16GB@1.33Ghz  -  Gigabyte 1660s -  TT smart RGB 700W  -
Cooler Master Storm Trooper  -  120GB Samsung 850 Pro   -  LTT Edition Chromax NH-D15 ?
CrumpleBox 3 ROTF: I5-6400  -  MSI B150m Mortar  -  16GB 2133Mhz Vengeance Pro RGB  -  Strix 1070Ti - GTX 1070 FE  -  Adata 128GB SSD  -  Fractal Design Define C  -  Gammaxx 400V2  -  Cooler Master silent pro gold 1000W
CrumpleBox 2: i7-7820x - MSI X299 Raider - 32GB Thermaltake Toughram 3.6Ghz - 2x Sapphire Nitro Fury - 128GB PCie Adata SSD - O11 Dynamic - EVGA CLC 360 - Corsair RM1000X
Perhiperals:  Gateway 900p60 monitor  -  Dell 1024x768@75  -  Logi. G403 Carbon  -  Logi. G502  -  SteSer. Arctis 5  -  SteSer. Rival 110 - Corsair Strafe RGB MK.2
https://linustechtips.com/topic/927204-help-me-upgrade-my-pc/#findComment-11345174
Z170 is not compatible with the 8700k without serious modding. Best you can get now is a 7700K
Primary Laptop (Gearsy MK4): Ryzen 9 5900HX, Radeon RX 6800M, Radeon Vega 8 Mobile, 24 GB DDR4 2400 Mhz, 512 GB SSD+1TB SSD, 15.6 in 300 Hz IPS display
2021 Asus ROG Strix G15 Advantage Edition
Secondary Laptop (Uni MK2): Ryzen 7 5800HS, Nvidia GTX 1650, Radeon Vega 8 Mobile, 16 GB DDR4 3200 Mhz, 512 GB SSD
2021 Asus ROG Zephyrus G14
Meme Machine (Uni MK1): Shintel Core i5 7200U, Nvidia GT 940MX, 24 GB DDR4 2133 Mhz, 256 GB SSD+500GB HDD, 15.6 in TN Display
2016 Acer Aspire E5 575
Retired Laptop (Gearsy MK2): Ryzen 5 2500U, Radeon Vega 8 Mobile, 12 GB 2400 Mhz DDR4, 256 GB NVME SSD, 15.6" 1080p IPS Touchscreen
2017 HP Envy X360 15z (Ryzen)
PC (Gearsy): A6 3650, HD 6530D , 8 GB 1600 Mhz Kingston DDR3, Some Random Mobo Lol, EVGA 450W BT PSU, Stock Cooler, 128 GB Kingston SSD, 1 TB WD Blue 7200 RPM
HP P7 1234 (Yes It's Actually Called That)  RIP
Also im happy to answer any Ryzen Mobile questions if anyone is interested!
https://linustechtips.com/topic/927204-help-me-upgrade-my-pc/#findComment-11345179
Personally, I picked up an asus z370 maximus x hero (wifi/ac) and I am in love. A great motherboard, 1 click 5ghz overclock, a heatsink for m.2 drive, bluetooth/wifi (I wanted the bluetooth), back panel usb type c port, no backplate needed to attach to case, nice aesthetics... It's an all around good board.
https://linustechtips.com/topic/927204-help-me-upgrade-my-pc/#findComment-11345216
2 minutes ago, KreckyN_ said:
I already have 144hz monitor. I have money to spare so i wanna push some FPS. Not good enough for me i would say :>
Cool. Then get a new GPU. And maybe an unlocked i7 of that generation if you're really insitent on upgrading it. Then OC the crap out of all of it.
What are you planning on playing? I don't think its worth throwing in the towel with your current setup although I appreciate I am in the minority.
Probably gaming or helping technophobes with tech...
https://linustechtips.com/topic/927204-help-me-upgrade-my-pc/#findComment-11345260
I would wait for a new architecture if you have a 970. I personally don't like to upgrade every generation.
Also for the CPU, do you really need the upgrade? Do you need more horsepower than you currently have?
I would personally wait for a new generation of both GPUs and CPUs and see what performance gains are there.
If you really want to upgrade, any Z370 is good enough, so go with any unless you want to do some serious overclocking.
CPU: Ryzen 7 9800X3D Cooler: Noctua NH-D15 Black Mobo: Gigabyte X870E Aorus Pro GPU: Sapphire Nitro+ 9070 XT RAM: G.Skill 2x16GB @ 6400 MHz SSD: PNY XLR8 2TB PSU: Corsair RM1000x Case: Fractal Design North Monitor 1: Asus XG27AQWMG(280Hz) Monitor 2: Asus VG259QM (240Hz)
I usually edit my posts immediately after posting them, as I don't check for typos before pressing the shiny SUBMIT button.
Unraid Server
CPU: Ryzen 5 7600 Cooler: Noctua NH-U12S Mobo: Asus B650E-i RAM: Kingston Server Premier ECC 2x32GB (DDR5) SSD: Samsung 980 2x1TB HDD: Toshiba MG09 1x18TB; Toshiba MG08 2x16TB HDD Controller: LSI 9207-8i PSUCorsair SF750 Case: Node 304
https://linustechtips.com/topic/927204-help-me-upgrade-my-pc/#findComment-11345355
