So making a dual pc streaming build in the new 1000D (yea overkill iknow lol) and wasnt sure if i could get away wirh the mini itx build being off a ryzen 3. Wanted to use it to record and stream 1080p 60fps. Thoughts?
Main pc is 8700k with 1080. Going to get 1180s sli or the ti sli eventually.
https://linustechtips.com/topic/926969-stream-and-record-1080p/
If you sold the mITX system and your Intel CPU/mobo you could probably buy a AM4 Mobo and get a Ryzen 7 chip and do everything on one system.
Laptop: 2024 16" MacBook Pro M4 Pro, 512GB, 48GB Unified Memory | Phone: iPhone 16 Pro Max 512GB | Wearables: Apple Watch SE | Car: 2025 Honda Accord SE & 2007 Ford Taurus SE | CPU: R7 5700X | Mobo: ASRock B450M Pro4 | RAM: 32GB 3200 | GPU: Sapphire Nitro+ 9070XT | Case: Fractal North | OS: Win 11 | Storage: 1TB Crucial P3 NVME SSD, 1TB PNY CS900, & 4TB WD Blue HDD | PSU: Seasonic Focus GX-850 | Display: LG 27GL83A-B 1440p @ 144Hz, Dell S2719DGF 1440p @144Hz | Cooling: Noctua NH-U12S | Keyboard: G610 Orion Cherry MX Brown | Mouse: G305 | Audio: Audio Technica ATH-M50X & Blue Snowball | Server: 2024 M4 Mac mini, 256GB SSD, 16GB Unified Memory | Storage: Terramaster D4-320 DAS (12TB Seagate Ironwolf Pro, 12TB Seagate Ironwolf, 6TB WD Blue HDD, 500GB Crucial SSD)
https://linustechtips.com/topic/926969-stream-and-record-1080p/#findComment-11342482
3 minutes ago, DrMacintosh said:
I currently stream and record on my main pc, I also really wanted the 1000D when i saw kt last yearand figured id make a second build lol.
4 minutes ago, Electronics Wizardy said:
Was looking at the 1300x
4 minutes ago, Some Random Member said:
Just trying to stay away from the single pc setup
https://linustechtips.com/topic/926969-stream-and-record-1080p/#findComment-11342500
7 minutes ago, Electronics Wizardy said:
Id probably look at a 2400g, faster cpu, and igpu so you don't need a dgpu for this.
Thats another i had in mind. Could use a dgpu since i already have one. I do have a 6600k aswell. But cant a decent priced mini itx board
https://linustechtips.com/topic/926969-stream-and-record-1080p/#findComment-11342529
