High overclock on samsung monitor
DarthSmartt
I am using some basic 19:9 1080p monitor that my dad gave me( he had it since probobly 2008 or 9). I have just managed to oc it from 60 to 83hz so far. is it dangerous to push it further if i go up by increments of one? (that's what she said)
Build:
Intel Core I7 6700k (clocked to 4.6ghz)
Patriot Viper 3000mhz ddr4
ASUS maximus 8 hero (I hate this mobo)
Evga gtx 1080 superclocked
250GB Samsung 850 evo
2tb WD Black 7200rpm
Ek watercooling kit a240g with 360 expansion pack
Primochill Vue Red fluid
Corsair Graphite 600t (white)
You thought "Gee, Donald Trump sure has a great build!"
You can usually OC a 60hz monitor to about 2,000,000 hz(On average, your mileage may vary somewhat) with a voltage of about 2.0136589261927361V. Just don't push it any fuhrer than 4,000,000 though, as you may need to turn the voltage and fan speed to unhealthy levels. By the way, don't go for anything less than increments of 90.7819364 hz at a time.
REMEMBER:
IF YOU WANT ME TO RESPOND, YOU GOTTA QUOTE ME
OR
PUT @Fixinit1 IN YOUR RESPONSE!!!!!
Gosh, I hate it when people forget. Anyway, check out my PC below, and there's a PCPartPicker link on my profile, If you wanna see what I'm planning.
SYSTEM SPECS: Finally ditched the Pentium N3540, now I've got the following:
CPU - Ryzen 5 2400G
GPU - 1060 6GB Gigabyte G1 Gaming
RAM - 16GB DDR4 3000mhz Team T-Force Delta RGB
MOTHERBOARD - MSI B350 Tomahawk
PSU - EVGA 450BT
CASE - PHANTEKS  P350X
I answered my own question with google and common sense. The image got fuzzy at 84 an i found my monitor shuts off after 5 min with a "not optimum mode" error on anything over 77.
Build:
