You shouldn't be overclocking on the stock heatsink. Buy an aftermarket cooler. Something like a Cryorig H7 if you want to stay on the cheap side (although you won't be able to push it as far), or something like a Dark Rock Pro 3 Noctua NH D14/D15 if you want to overclock further.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
You shouldnt be worried of parts underperforming, because this is a clear case of getting what you paid for.
You should be worried about the lifespan of the CPU though.
Desktop benching:
32 minutes ago, yugi8264 said:
I just bought a 8700k and I am using the stock heatsink from my old 4700k.
Are you serious? You planned a long time for your build, asking alot of questions about different topics but you are using the 4700k stock cooler?
CPU: Ryzen 7 5800x3D | MoBo: MSI MAG B550 Tomahawk | RAM: G.Skill F4-3600C15D-16GTZ @3800CL16 | GPU: RTX 2080Ti | PSU: Corsair HX1200 |
Case: Lian Li 011D XL | Storage: Samsung 970 EVO M.2 NVMe 500GB, Crucial MX500 500GB | Soundcard: Soundblaster ZXR | Mouse: Razer Viper Mini | Keyboard: Razer Huntsman TE Monitor: DELL AW2521H @360Hz |
35 minutes ago, yugi8264 said:
I just bought a 8700k and I am using the stock heatsink from my old 4700k. The temps for cpu are already 80-100+ when I oc to 4.7 ghz. Should I be worried.
100% yes. Return to stock immediately. Maybe even dial it back below stock.  The fact that it's reaching 100C without thermal throttling is concerning, because it's going to fry your CPU. The reason it doesn't come with a cooler is because no stock cooler can sufficiently cool it. Buy a Cryorig H7.
Make sure to quote or tag me (@JoostinOnline) or I won't see your response!
PSU Tier List  |  The Real Reason Delidding Improves Temperatures"2K" does not mean 2560×1440
