I need help with this build
Go to solution Solved by VEXICUS,
27 minutes ago, HaMoOoOd25 said:
Hello,
I created this build using pcpartpicker and I got everything on my budget with calculating the shipping cost. But I want to check the graphics card because I didn't find any reviews for it.
the build link https://pcpartpicker.com/list/thZrD2
The graphics card I used is Asus gtx 1060 6gb dual fan.
I wanted to have 16gb of ram but hell no that will break my budget waay far. I can have 16gb of ram but I prioritized the 250 ssd. without the ssd I can have this 16gb of ram but I would prefer to have the 8gb with the ssd then look forward upgrade later.
I just need any advice or changes I can do to this build.
by the way I am gonna buy the case from local store in my country its cheaper so I did not list the case. thank you.
Build something like this....
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($175.89 @ OutletPC)
Motherboard: ASRock - AB350M Pro4 Micro ATX AM4 Motherboard  ($74.39 @ OutletPC)
Memory: G.Skill - Aegis 8GB (1 x 8GB) DDR4-3000 Memory  ($88.98 @ Newegg)
Storage: Crucial - MX500 250GB 2.5" Solid State Drive  ($69.99 @ Amazon)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($59.79 @ OutletPC)
Video Card: Asus - GeForce GTX 1060 6GB 6GB Dual Video Card  ($289.98 @ Newegg)
Power Supply: Cooler Master - MasterWatt 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($31.65 @ Newegg)
Total: $790.67
Generated by PCPartPicker 2018-05-13 09:53 EDT-0400
Hello,
https://linustechtips.com/topic/926526-i-need-help-with-this-build/
6 minutes ago, HaMoOoOd25 said:
Hello,
Asus GFX cards are fine.
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
get a better psu but otherwise it's fine.
What do you suggest me for the psu ?
is this one good. its more expensive but many recommended it for me : https://www.amazon.com/Corsair-Bronze-Certified-Modular-CP-9020102-NA/dp/B01B72W0A2/ref=sr_1_1?s=electronics&ie=UTF8&qid=1526218836&sr=1-1&keywords=corsair+power+supply
look for a corsair CX450/M or coolermaster masterwatt.
Hello,
Total: $790.67
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
44 minutes ago, HaMoOoOd25 said:
Hello,
PCPartPicker part list: https://pcpartpicker.com/list/3YCtnH
Price breakdown by merchant: https://pcpartpicker.com/list/3YCtnH/by_merchant/
Motherboard: MSI - B350 PC MATE ATX AM4 Motherboard  ($69.90 @ OutletPC)
Memory: G.Skill - Aegis 16GB (2 x 8GB) DDR4-3000 Memory  ($152.99 @ Newegg)
Storage: ADATA - Ultimate SU650 240GB 2.5" Solid State Drive  ($53.99 @ Newegg Marketplace)
Storage: Hitachi - Deskstar 1TB 3.5" 7200RPM Internal Hard Drive  ($37.00 @ Newegg Marketplace)
Video Card: Asus - Radeon RX 570 4GB ROG STRIX Video Card  ($239.99 @ Newegg)
Case: Corsair - Carbide SPEC-04 (Black/Yellow) ATX Mid Tower Case  ($32.50 @ Newegg)
Power Supply: Corsair - TXM Gold 550W 80+ Gold Certified Semi-Modular ATX Power Supply  ($44.99 @ Newegg)
Total: $807.25
Generated by PCPartPicker 2018-05-13 10:10 EDT-0400
Total: $790.67
But isn't it better to have 2x4 for more performance or its just when I make an upgrade
Ryzen Apus perform better with faster dual channel memory.....whereas ryzen first gen CPUs perform similar in single channel and dual channel....
Watch this..
SSD TIER LIST
CPU - Ryzen 7 3700X
