one friend of mine was asking me to give him a build within 60k BDT or 700 dollars and he was on tight budget but the parts In Bangladesh is expensive from US Or Canada for Taxes and others i completed a build but there was no money left to buy an aftermarket cooler.
So,my question is 'Can i Run i5 8400 nicely with Stock Cooler or I need a Aftermarket Cooler'
https://linustechtips.com/topic/925185-stock-cooler/
It will run but it will get very hot in full load for a long period of time i wont even mention oc.Just buy an aftermarket cooler when u can.
https://linustechtips.com/topic/925185-stock-cooler/#findComment-11325849
The i5 8400 is fine to go with the stock cooler, aside the bad noise it'll work just fine.
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/925185-stock-cooler/#findComment-11325855
Its locked CPU... and its not of hot variety either. Stock will be fine, and OP/their friend can setup manual volts if it would get toasty.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/925185-stock-cooler/#findComment-11326585
