Is it worth using DVI-D dual link anymore?
Solved by Princess Luna,
You mean change it just for the sake of changing? why?
DVI-D is HDMI in the "heart" there is no difference actually depending how old the HDMI revision is you can't even do 144hz at 1080p with it so better just stick to what works, it's not like your image will get any better because the cable you're using.
Featured Topics
Steven Schaefer ·
Posted in Troubleshooting0 -
Beta2099 ·
fanman1980 ·
Posted in Hobby Electronics0 -
cherry waves ·
Posted in General Discussion3 -
LDinos ·
Posted in Troubleshooting2 -
DarkAngelHD123 ·
Posted in Peripherals3 -
7
