Where do I get cherry mx blue rgb switches
Where do I get a set of cherry mx blue rgb switches? The ones that have a see-through design instead of one that are black. NOT A CHERRY MX BLUE KEYBOARD, JUST THE RGB SWITCHES.
Weren't they Corsair exclusive?
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
There have been other brands with these switches so idk
Hey, so I did some investigating and your most likely going to have to buy aftermarket switches from China. RGB blue switches are becoming increasingly a rare find, yet here's the link to one that I found:
https://www.banggood.com/10PCS-3-Pin-Mechanical-Keyboard-Switch-Blue-Switch-for-Gateron-Keyboard-Replacement-p-1119472.html?rmmds=buy&cur_warehouse=CN
Also MassDrop is also selling these:
https://www.massdrop.com/buy/outemu-switches-120-pack
Edit: This link actually doesn't work
MX Browns are the future... indeed it is rare nowadays post above seems a good way to go.
Personal Desktop":
Luna, the temporary Desktop:
The LEDs are on the board. If you're looking into building a board get ready to spend upwards of $100+ on parts and $100 alone on the soldering set.
You can buy cheap gateron (cherry mx clones) for cheap on places like AliExpress or banggood.
Ion (Main Build)        Overall Setup
i5 6500 3.2 GHz        -Blue snowball (White) thanks goodwill
MSI Mortar Arctic        -Logitech K120
Asus 1060 6GB Dual                                                             -Logitech Daedalus Prime G302
PNY CS1311 120 GB                                                            -Mousepad I made in 1st grade with my name on it
WD Caviar Blue 1 TB
Crucial Ballistix Sport LT White 16GB (8x2GB) 2400
NZXT S340 White
Corsair CXM 450W
Lenovo H320 (Old Pre-built PC)                                      Possible upgrade for H320
i5 650 3.2 GHz (heh)        Xeon X3470
Motherboard unknown                                                       Same Motherboard
iGPU        GT 1030 (MSI Low Profile Half Height)
Crucial 240GB SSD                                                           Crucial 240GB SSD
6GB DDR3 (4+2GB)                                                           8-10GB DDR3 (4+2+2GB/4+4+2GB)
Lenovo H320 case                                                             Lenovo H320 case
Unknown PSU (210W?)                                                     Same PSU (210W?)
Just went and bought a set of these to replace some switches that lost the strong click due to liquid spills (cleaned and work fine but not as clicky) thanks for the link, consequently can update thread if OP is willing to wait about 3 weeks :P
CPU: AMD Sempron 2400+ / MOBO: Abit NF7-S2G / GPU: WinFast A180BT 64MB / RAM: Mushkin DDR333 256MBx2 / HDD: Seagate Barracuda 7200RPM 120GB
Depending on skill/patience, the job could be done with about $40 worth of soldering gear, though a proper station is always better. I remember my $15 20W Weller pencil iron days
Are those rgb?
4 minutes ago, ThiccSon said:
Are those rgb?
the switches aren't, as stated previously the LED's are part of the board circuitry itself (at least true in my case and likely most). the switches simply are designed with cutout for said LED to shine through and the design of current KB switches match that of the ones linked that I ordered.
  • 4 weeks later...
Well they finally arrived two days ago. Legit gateron switches. So far only needed to replace the spacebar otemu switch on my keyboard but the gaterons from that site are completely fine.
