Need an advice about monitor
Hello. I am thinking of buying a new monitor but I need some professional help. Currently I have Samsung LS24E390HLO FHD PLS monitor with a refresh rate of 60Hz. I play video games everyday and somewhere I heard that Higher is the monitor refresh rate, better it is for gaming. After having watched some videos on YouTube, including ones from "Techquickie", I decided to look for an FHD IPS monitor with a refresh rate of 120Hz or 144Hz. How do you think, is it a good idea or not? Does it really make significant difference in games and should I look for 144Hz monitors only or 120Hz will still be a good upgrade from 60Hz?
Specs: i5 7500 3.4GHz |  MSI GTX 1060 Gaming X 6G | Corsair Vengeance 16GB | Asus Prime Z270-P
i5 7500 3.4GHz
Asus Prime Z270-P
Corsair Vengeance LPX DDR4 3000Mhz 16Gb (2x8GB)
Samsung 970 EVO PLUS 250GB NVMe
Seagate Firecuda 2TB SSHD
first, what are your specs. it's nice to know if your pc can handle it at all before diving more into the monitors
~i5-7600k @5GHz ~Be Quiet! Dark rock 3 ~MSI GTX 1070 Gaming X 8G ~Gigabyte GA-Z270-gaming K3 ~Corsair Vengeance Red led ~NZXT S340 Elite
Yes there's a noticable difference.. Even your mouse movement feels more smoother on 144Hz than on 120Hz in general.. Once you buy higher refresh monitor you never will regret it tbh xD
27 minutes ago, Glenwing said:
There are no 120+ Hz IPS monitors at that resolution.
There are some decent VA monitors though, like the Samsung C24FG73.
https://rog.asus.com/articles/gaming-monitors/press-release-republic-of-gamers-announces-swift-pg27uq/
This one is 4K, 144hz, and IPS
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
Edited original post, so you can now see the specs.
i5 7500 3.4GHz
Asus Prime Z270-P
11 minutes ago, Glenwing said:
I said there are no 120+ Hz IPS monitors at Full HD (1920×1080)
OOPS, my bad. But this brings up the question, why are there 4K 144hz IPS displays but no 1080p 144hz IPS displays?
you will most likely have to turn down settings, towards medium, in big titles to get the 144fps. if you don't mind that then i'd say get a monitor with a Va panel, so that colors are pretty decent.
100hz+ vs 60hz is supposedly a nice upgrade. haven't seen it for myzelf, but only heard good things about it
