External HDD problem
Go to solution Solved by rheyL,
5 hours ago, Akshat Sharma said:
The HDD actually powered up and I could feel the hard drive spinning
your external hdd format? ntfs or fat32? and your phone model?
i am using a Samsung Note 3 and it can run external hdd but using  a fat32 format, and if i want it to run on ntfs, needs to be rooted.
I have an external hdd which has some movies and I am travelling right now, so I wanted to watch them on my phone. Using an otg cable I connected the hdd to my phone and it started spinning. But, my phone was showing it as corrupt although as soon as I checked it using a laptop, everything was intact and I was able to write and read data easily. What caused this problem?
https://linustechtips.com/topic/923820-external-hdd-problem/
I doubt your phone can power a physical HDD
Laptop: 2024 16" MacBook Pro M4 Pro, 512GB, 48GB Unified Memory | Phone: iPhone 16 Pro Max 512GB | Wearables: Apple Watch SE | Car: 2025 Honda Accord SE & 2007 Ford Taurus SE | CPU: R7 5700X | Mobo: ASRock B450M Pro4 | RAM: 32GB 3200 | GPU: Sapphire Nitro+ 9070XT | Case: Fractal North | OS: Win 11 | Storage: 1TB Crucial P3 NVME SSD, 1TB PNY CS900, & 4TB WD Blue HDD | PSU: Seasonic Focus GX-850 | Display: LG 27GL83A-B 1440p @ 144Hz, Dell S2719DGF 1440p @144Hz | Cooling: Noctua NH-U12S | Keyboard: G610 Orion Cherry MX Brown | Mouse: G305 | Audio: Audio Technica ATH-M50X & Blue Snowball | Server: 2024 M4 Mac mini, 256GB SSD, 16GB Unified Memory | Storage: Terramaster D4-320 DAS (12TB Seagate Ironwolf Pro, 12TB Seagate Ironwolf, 6TB WD Blue HDD, 500GB Crucial SSD)
https://linustechtips.com/topic/923820-external-hdd-problem/#findComment-11312388
Exactly this ^^
That HDD probably uses more power than rest of your phone.
CPU: i7 3770K | MB: EVGA Z77 FTW | RAM: HyperX Savage 2400Mhz 16GB | GPU: R9 280X Toxic | Cooler: Scythe Fuma | PSU: CoolerMaster B600
SSD: Crucial MX300 525GB | HDD: Seagate Barracuda 7200.12 500GB - Toshiba DT01ACA300 3TB
https://linustechtips.com/topic/923820-external-hdd-problem/#findComment-11312422
https://linustechtips.com/topic/923820-external-hdd-problem/#findComment-11314812
Its NTFS, that's why I think it was showing as corrupt. After rooting do I have to do additional stuff or it will detect the HDD automatically? My phone model is Xiaomi Redmi Note 4(mido)
https://linustechtips.com/topic/923820-external-hdd-problem/#findComment-11315431
i have no idea about xiaomi phones, sorry ?
https://linustechtips.com/topic/923820-external-hdd-problem/#findComment-11317664
