While using dxtory with the lagarith loseless codec and recording some minecraft at 720P 30 fps. The program eats up about 1 gb a minute is this suppose to be normal? Because if this is so then, rendering and uploading to youtube will be quite a hassle with the amount of time it will take.
Wanna hang out with me and people like @Theslsamg, @ Ssoele, @BENTHEREN, @Lanoi, @Whiskers, @_ASSASSIN_, @Looney, @WunderWuffle, and @nsyedhasan. Well.... Check out: http://linustechtips.com/main/topic/48484-unofficial-linustechtips-teamschnitzel-server-teamspeak/
https://linustechtips.com/topic/92363-dxtory-problem/
-.-, my windows media player is giving me problems. It's not displaying my videos that I've rendered. It only somehow plays only the audio.
https://linustechtips.com/topic/92363-dxtory-problem/#findComment-1244394
It's normal with 1gb a min so just use something like windows movie maker so render it :)
how about sony vegas?
https://linustechtips.com/topic/92363-dxtory-problem/#findComment-1245536
1gb a minute is normal for Dxtory. You can try to render them out in an editing program to try to compress them a bit though, just so you dont have +20gb files uploading to YouTube or whatnot.
What kind of compression program do you recommend or should I just like zip it? btw I'm having problems with my windows media player. It's not playing my avi videos for some reason. Like the audio part of the video would play but not the video. It's just all black could you help me on this?
https://linustechtips.com/topic/92363-dxtory-problem/#findComment-1245548
Try using Sony Vegas, it is full of alot of really cool items and gives you alot of flexibility when it comes to video editing. You should be able to acquire it Barbary(Pirate) style.
https://linustechtips.com/topic/92363-dxtory-problem/#findComment-1245587
mind helping me out on that second part of my comment. WMP is being quite weird.
https://linustechtips.com/topic/92363-dxtory-problem/#findComment-1245600
My recordings get end up being around 150GB for an hour or so, but for quality content you want to edit anyway. So after editing and what not, rendering out in either Vegas or Premiere brings it down to around 3-5GB. Both Vegas and Premiere have YouTube specific render presets
I am good at computer
Motherboard: Gigabyte G1 sniper 3 | CPU: Intel 3770k @5.1Ghz | RAM: 32Gb G.Skill Ripjaws X @1600Mhz | Graphics card: EVGA 980 Ti SC | HDD: Seagate barracuda 3298534883327.74B + Samsung OEM 5400rpm drive + Seatgate barracude 2TB | PSU: Cougar CMX 1200w | CPU cooler: Custom loop
https://linustechtips.com/topic/92363-dxtory-problem/#findComment-1245617
It really goes down to that much really?
https://linustechtips.com/topic/92363-dxtory-problem/#findComment-1245673
For YouTube presets, yes. It can be compressed that much because YouTube video always looks bad so there's not really a difference between less compressed footage
https://linustechtips.com/topic/92363-dxtory-problem/#findComment-1245744
reduce the quality. dont use 100%..97% takes less. its exponential. try 90%.
I used 100% and reendered it in sony vegas ..then TADA 1MB/sec
CPU: Ryzen 5500 GPU: RX 6800 RAM: DDR4 3200MHZ 48GB (2x8+2x16 GB)  MOBO: MSI B450-A PRO Display: 4k120hz with freesync premium.
https://linustechtips.com/topic/92363-dxtory-problem/#findComment-1247363
Mind showing me this stuff over skype? I've messaged you.
https://linustechtips.com/topic/92363-dxtory-problem/#findComment-1248065
What do you mean by that?
https://linustechtips.com/topic/92363-dxtory-problem/#findComment-1248455
If the rcording lasts 1hour it would take 60x60x1= 360MB
but I exagerated it.. but its like still a big deal.
https://linustechtips.com/topic/92363-dxtory-problem/#findComment-1249391
