Anyone else had an issue where the Asus z370 gaming e won't overclock an i7 8700k? Only way I could get mine to overclock was disabling vrm thermal protection. I'm running at 5 ghz at 1.376 volts hitting around 70c on custom loop delided. Before I disabled this it would throttle down after 5 minutes of prime 95 with avx off.
My rig
Asus maximus z390
I9 9900k @ 5.2 Ghz 24/7 (5.4 Ghz benching)
Evga RTX 3090 ftx ultra
32GB Gskill trident z 3866 Mhz
1000 watt evga gold psu
All watercooled
https://linustechtips.com/topic/923166-asus-z370-gaming-e-problems/
it's normal. This thing has mediocre VRMs.
Desktop benching:
1 hour ago, App4that said:
Just set your LLC (load line calibration) to level 6. Should clear it up.
Yeah It is on 6, doesn't matter. It would throttle down. Maybe the vrms heatsink is lose or something.
My rig
Asus maximus z390
All watercooled
