2 minutes ago, patriciadiaz1919 said:
it didnt come with one it new so i need to buy one
Yeah I got a free sim from a Rogers store, but most you pay.
I needed it to get into the phone and reset it back to factory default since it was a used mobile phone and I needed to bypass the password.
https://linustechtips.com/topic/923017-phone-carrier-help/#findComment-11304611
will the compnay unllocked the carrier for free for some other phones who i may not have the info or bills where i bought it from
https://linustechtips.com/topic/923017-phone-carrier-help/#findComment-11304695
On 5/3/2018 at 1:42 PM, Canada EH said:
you can try and see what comes of it
i have a cricket phone order from the online store  kyocera hydro view not sure i can buy a number online to unlock carrier as i read it some says i need to use it for 6 months by there company
https://linustechtips.com/topic/923017-phone-carrier-help/#findComment-11311029
Oh I got no idea, I know for Fido a few years back I picked my own number, of course Rogers owns them its their value brand. Took me 4 or 5 hours to go through all the cities and find the best phone numbers there was at that time. Its a keeper! I checked the other day and its all the new area code BS. All I did was port the number to a different carrier, on Bell. It was instant. Best thing I ever did was spend those hours finding the easiest numbers for people to remember. You know how you have those numbers like 1800growers or something like that, well I got one of those, plus a 780-955-5000 type of number. Best thing I ever did.
I dont know about Cricket but I am sure they are all the same for porting. Its just each carrier has a different method oh assigning phone numbers. Thats why I went through 4 or 5 different companies in what I did, buying a SIM card for each one. Like I said its the best thing I ever did. You dont want a business with a phone number too hard to remember, nor do you want a personal phone number thats hard to remember.
https://linustechtips.com/topic/923017-phone-carrier-help/#findComment-11311791
Well that's a hard post to read. You should really take some time to add punctuation into your posts.
You can try calling Cricket for the unlock code, but I believe in the US you'll have to pay a fee to unlock it. You could also look on eBay, there's usually unlock codes available on there for a few dollars.
On 5/2/2018 at 8:22 PM, Canada EH said:
you need the sim card that the phone is locked to
No, no you don't. It doesn't lock the phone to a SIM card, the phone is locked to the network.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/923017-phone-carrier-help/#findComment-11316405
what do i do i got this crickt phone that i got letter from the sim unlcoker companionways had errors from that c company and the cricket told me to use there services for 6 months
https://linustechtips.com/topic/923017-phone-carrier-help/#findComment-11318731
You can try another company, but likely you can't unlock it.
https://linustechtips.com/topic/923017-phone-carrier-help/#findComment-11320264
