there are sensors on the motherboard, CPU and graphics card that records their power draw and HWinfo can report them. However, these are mostly inaccurate, and does not record other stuff like HDDs and RGB lights' power draw. A power meter is what you need.
Desktop benching:
https://linustechtips.com/topic/922737-pc-power-consumption/#findComment-11302042
5 hours ago, angelospao13 said:
Hello, is there any program to monitor the watt that my pc drains ?
No, you need a Hardware Device to measure that.
There are a hand full of PSU that can monitor that.
"Hell is full of good meanings, but Heaven is full of good works"
https://linustechtips.com/topic/922737-pc-power-consumption/#findComment-11302916
To be actually accurate you need hardware outside of your PC. Some software can hook up to load testers.
A Corsair RMi/HXi have capabilities if using Corsair Link, that allow you to read pretty accurately how much voltage is being demanded by the PSU. You can also use a Kill-A-Watt and measure how much power is drawn from the wall, and do napkin math based on the efficiency of your PSU to get a rough idea of how much power is being demanded by the system from the PSU.
https://linustechtips.com/topic/922737-pc-power-consumption/#findComment-11302973
I've thinking in getting one of these for my setup
https://www.amazon.co.uk/80-300V-0-100-0A-Voltmeter-Ammeter-Display/dp/B06XX8NFY4
but if you only want to measure the PSU something like this should work, search for one with the plug you need
https://www.amazon.co.uk/UEB-Electricity-Analyzer-Overload-Protection/dp/B01EUE2FRW/
ASUS X470-PRO • R7 1700 4GHz • Corsair H110i GT P/P • 2x MSI RX 480 8G • Corsair DP 2x8 @3466 • EVGA 750 G2 • Corsair 730T • Crucial MX500 250GB • WD 4TB
https://linustechtips.com/topic/922737-pc-power-consumption/#findComment-11302977
