Hi there, this summer I plan to reach my goal for my pc and finally build or buy a pre-built. I live in the US and wil roughly have $1500 for a whole setup including peripherals. I do like HyperX so maybe those peripherals can be fit in there. I plan to play at 1080p on most titles. Some of the main ones I will play are PUBG, CS GO, Fortnite, Battlefield, and Rocket League. I will attach what I have so far on my list and hopefully some people can give advice to the processor, cooler, and graphics cars. Lastly, looking for a processor to handle both streaming and gaming. Leaning more towards intel. Thanks in advance!
https://pcpartpicker.com/list/KZqgtg
https://linustechtips.com/topic/922245-first-build-summer-2018/
An 8700k, also idk how good that PSU is.
Ion (Main Build)        Overall Setup
i5 6500 3.2 GHz        -Blue snowball (White) thanks goodwill
MSI Mortar Arctic        -Logitech K120
Asus 1060 6GB Dual                                                             -Logitech Daedalus Prime G302
PNY CS1311 120 GB                                                            -Mousepad I made in 1st grade with my name on it
WD Caviar Blue 1 TB
Crucial Ballistix Sport LT White 16GB (8x2GB) 2400
NZXT S340 White
Corsair CXM 450W
Lenovo H320 (Old Pre-built PC)                                      Possible upgrade for H320
i5 650 3.2 GHz (heh)        Xeon X3470
Motherboard unknown                                                       Same Motherboard
iGPU        GT 1030 (MSI Low Profile Half Height)
Crucial 240GB SSD                                                           Crucial 240GB SSD
6GB DDR3 (4+2GB)                                                           8-10GB DDR3 (4+2+2GB/4+4+2GB)
Lenovo H320 case                                                             Lenovo H320 case
Unknown PSU (210W?)                                                     Same PSU (210W?)
https://linustechtips.com/topic/922245-first-build-summer-2018/#findComment-11296872
Build something like this....
CPU: Intel - Core i5-8400 2.8GHz 6-Core Processor  ($178.99 @ Amazon)
CPU Cooler: CRYORIG - H7 49.0 CFM CPU Cooler  ($34.89 @ OutletPC)
Motherboard: ASRock - B360M Pro4 Micro ATX LGA1151 Motherboard  ($87.31 @ Newegg)
Memory: Team - T-Force Delta RGB 16GB (2 x 8GB) DDR4-3000 Memory  ($159.99 @ Newegg)
Storage: Crucial - MX500 250GB 2.5" Solid State Drive  ($69.99 @ Adorama)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($59.79 @ OutletPC)
Video Card: EVGA - GeForce GTX 1070 Ti 8GB SC GAMING ACX 3.0 Black Edition Video Card  ($509.99 @ Amazon)
Case: Phanteks - ECLIPSE P400S TEMPERED GLASS ATX Mid Tower Case  ($59.99 @ Newegg)
Power Supply: SeaSonic - FOCUS Plus Gold 550W 80+ Gold Certified Fully-Modular ATX Power Supply  ($54.99 @ Newegg)
Operating System: Microsoft - Windows 10 Pro OEM 64-bit  (Purchased For $35.00)
Keyboard: Corsair - K65 RGB Wired Gaming Keyboard  ($87.54 @ Amazon)
Mouse: Logitech - G502 Proteus Spectrum Wired Optical Mouse  ($49.99 @ Amazon)
Headphones: Kingston - HyperX Cloud II 7.1 Channel  Headset  ($90.53 @ Amazon)
Total: $1478.99
Generated by PCPartPicker 2018-04-30 16:39 EDT-0400
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
https://linustechtips.com/topic/922245-first-build-summer-2018/#findComment-11296902
it is good but too expensive for what is is
Total: $1478.99
I would avoid any i5s for streamming, at least in that price range
https://linustechtips.com/topic/922245-first-build-summer-2018/#findComment-11296939
CPU: Intel - Core i5-8600K 3.6GHz 6-Core Processor  ($237.99 @ SuperBiiz)
CPU Cooler: Corsair - H100i v2 70.7 CFM Liquid CPU Cooler  ($94.99 @ Amazon)
Motherboard: ASRock - Z370 Extreme4 ATX LGA1151 Motherboard  ($147.28 @ Newegg)
Video Card: EVGA - GeForce GTX 1080 8GB Superclocked Gaming ACX 3.0 Video Card  ($604.98 @ Newegg)
Total: $1524.99
Thank you for the response! Now Idk a lot about parts but I’ve been told asrock doesn’t have quality mother boards, could I switch it out?
Also, will the 8600k with its 6 cores and only 6 threads be able to handle gaming and streaming ?
https://linustechtips.com/topic/922245-first-build-summer-2018/#findComment-11296948
I didn't read the streaming part.....fr streaming+gaming...this should be better...
CPU: AMD - Ryzen 5 2600X 3.6GHz 6-Core Processor  ($228.89 @ OutletPC)
Motherboard: Gigabyte - X470 AORUS ULTRA GAMING ATX AM4 Motherboard  ($139.99 @ SuperBiiz)
Total: $1546.68
Generated by PCPartPicker 2018-04-30 16:46 EDT-0400
SSD TIER LIST
CPU - Ryzen 7 3700X
https://linustechtips.com/topic/922245-first-build-summer-2018/#findComment-11296951
Total: $1546.68
Thank you very much! If I decide To go Ryzen then the 2600x would be a great fit! And I think with Intel, the 8700k would be a good choice. Thank you for the input and help!
https://linustechtips.com/topic/922245-first-build-summer-2018/#findComment-11296957
ASROCK z360 extreme4 is one of the best budget gaming and overclockibg mobo
SSD TIER LIST
CPU - Ryzen 7 3700X
https://linustechtips.com/topic/922245-first-build-summer-2018/#findComment-11296958
Total: $1546.68
I'd rather get the 1700 which has 8 cores for that matter. 2nd gen cpus are overpriced right now the R5 1600 and R7 1700 are still the best deal
https://linustechtips.com/topic/922245-first-build-summer-2018/#findComment-11296961
I agree??
SSD TIER LIST
CPU - Ryzen 7 3700X
https://linustechtips.com/topic/922245-first-build-summer-2018/#findComment-11296964
What about thois?
https://pcpartpicker.com/list/NBWCzY
You could step up to the R7 1700 if you like
https://linustechtips.com/topic/922245-first-build-summer-2018/#findComment-11296974
Just now, skeeler88 said:
The R7 1700 is “better” than the R5 1600 correct ?
Well
3 minutes ago, seon123 said:
The B3 is a bit of a fire hazard. And as usual with EVGA branded PSUs, it's quite loud.
n1 EVGA power supplies aren't really made by EVGA
and secondly you can't expect the same result from a product just because it has the same brand on the label, There are silent EVGa psus
https://linustechtips.com/topic/922245-first-build-summer-2018/#findComment-11296991
Summer is still a month away, start planning the exact parts 1-2 weeks before your purchase.
As for the parts you've chosen:
You can get an RGB RAM kit at a decent speed for $50 less.
The WD Blue isn't particularly good, and is way overpriced. The MX500, MX300, SL308 or 860 Evo should cost about the same or less, and are better.
You should be able to get cheaper 1TB 7200RPM HDDs. Get one of those.
The B3 is a bit of a fire hazard, and is quite loud. There are plenty of decent units. 450W is plenty. The Whisper M and RMx are among the quietest ones.
You can get a Windows key from Reddit or Kinguin for $25
https://linustechtips.com/topic/922245-first-build-summer-2018/#findComment-11296993
That's why I said EVGA branded. Not EVGA made.
The only EVGA branded PSU that isn't loud is the T2. All of the rest is loud. And also, I said that it's as usual. That does leave room for exclusions.
https://linustechtips.com/topic/922245-first-build-summer-2018/#findComment-11296999
Okay I’ll write all this down. I’m still unsure of what processor and Graphics cards will suit my needs
https://linustechtips.com/topic/922245-first-build-summer-2018/#findComment-11297321
CPU: AMD - Ryzen 7 2700 3.2GHz 8-Core Processor  ($289.99 @ SuperBiiz)
Motherboard: ASRock - X370 Pro4 ATX AM4 Motherboard  ($89.99 @ Newegg)
Memory: Team - T-Force Delta RGB 16GB (2 x 8GB) DDR4-3000 Memory  ($162.99 @ Newegg)
Storage: Crucial - BX300 240GB 2.5" Solid State Drive  ($58.39 @ Amazon)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($58.33 @ OutletPC)
Case: DIYPC - Vanguard RGB ATX Mid Tower Case  ($74.98 @ Newegg)
Keyboard: Gigabyte - FORCE K83 Wired Standard Keyboard  ($39.69 @ Newegg)
Total: $1484.32
Generated by PCPartPicker 2018-04-30 22:31 EDT-0400
https://linustechtips.com/topic/922245-first-build-summer-2018/#findComment-11297891
Total: $1484.32
is there a big difference between the 2700 and the 2600x/2700x?
https://linustechtips.com/topic/922245-first-build-summer-2018/#findComment-11297899
the 2600x has 2 less cores while the 2700x has a higher clock speed and slightly better cooler.
https://linustechtips.com/topic/922245-first-build-summer-2018/#findComment-11297906
would you say the 2700 is better than the 2600x? If i go with an AMD build im able to put more money in the GPU and other places.
https://linustechtips.com/topic/922245-first-build-summer-2018/#findComment-11297915
it'll be better since you're doing streaming.
https://linustechtips.com/topic/922245-first-build-summer-2018/#findComment-11297993
