New battery worth it ?
Go to solution Solved by sicily428,
1 hour ago, gepowr said:
I've been using the Schenker/Clevo xmg p502 since quiet some time now (bought it from ebay for a very good price).
Specs:
i7 3740qm
8Gb 1600MHz DDR3
128Gb SSD
750Gb HDD
I really like using this laptop e.g. at my girlfriends house or at "lan partys" with my friends where we usually play lighter games (some rts, rocket league, overwatch) that run very well and smooth on this dated but still powerful laptop. The laptop is working fine, however it is certainly very old by todays standards and so are the components. E. g. the ssd was used for around 24000 hours, the hdd for 14000 hours. The ssd wrote about 10Tb in total, the hdd doesn't display this. If one of the drives fail it should be very easy to replace it since the laptop is quiet thick and hast a lot of quick accessable maintainance slots. The battery life has been very poor ever since i got it. I know that the hardware is very power hungry and i am also aware that this laptop wasn't built to last all day on a single charge, however HWinfo is reporting 64% battery wear and i think this info could be true. On power saving mode with nvidia optimus, i am able to get around 1 hour of web browsing/video watching out of a single charge. I have researched current battery prices for the xmg p502 and they retail for about 65-100€ new with 1 year warranty here in germany. The battery is also hot-swapable. So before i go out and buy one i want to hear from you guys if you think that it's worth upgrading such an old laptop. Thanks for your opinions!
that's a really good laptop. it is a clevo p150em so you have a socketed cpu and a mxm gpu. It's worth it
Specs:
i7 3740qm
8Gb 1600MHz DDR3
128Gb SSD
750Gb HDD
Main Rig:
CPU: i7 4790k -> Scythe Mugen 5 (Dual Arctic P12)
MoBo: Asus Z97 Pro Gamer
RAM: 32GB DDR3 1866MHz Crucial Ballistix Sport
GPU: EVGA GTX 1080 Gaming -> Arctic Accelero Twin Turbo ii
PSU: Bequiet Pure Power 10 700W
Case: Bequiet Pure Base 600
Mobile Gaming 1: (XMG Fusion 15)
CPU: i7 9750H
RAM: 32GB DDR4 2666MHz
GPU: RTX 2070 MAX-Q
Mobile Gaming 2: (XMG P502 Pro)
CPU: i7 3740QM
RAM: 16GB DDR3 1600MHz
GPU: GTX 675MX 4GB
Ultrabook: (Dell Inspiron 13 5378)
CPU: i5 7200U
RAM: 16GB DDR4 2133MHz
GPU: HD 620
Server:
CPU: Athlon II x4 630
MoBo: Gigabyte/Dell 4GJJT
RAM: 4GB DDR3 1066MHz
GPU: Radeon HD 5450 1GB
https://linustechtips.com/topic/921554-new-battery-worth-it/
My battery lasts for like an hour - an hour and a half, and i just tote around my charger.
Up to you. I think that price is great tbh.
My profile picure is real. That's what I look like in real life. I'm actually a blue and white African Wild Dog.
Ryzen 9 5900X - MSI Ventus 2x OC 3060 Ti - 2x8GB Corsair Vengeance LPX 3200MHz CL16 - ASRock B550 Phantom Gaming ITX/ax
EVGA CLC 280 + 2x140mm NF-A14 - Samsung 850 EVO 500GB + WD Black SN750 1TB - Windows 11/10 - EVGA Supernova G3 1000W
https://linustechtips.com/topic/921554-new-battery-worth-it/#findComment-11289780
31 minutes ago, TLCH723 said:
How often are you going to use it with just battery? If most of the time, then it might be worth it. If not, why bother
I would probably start using it for daily office/university stuff, since when the laptop is plugged in the fans tend to spin up very aggressivly. Cpu even gets to around 95° in Gta 5 but there's really not much i can do about it, already running it on a cooling pad most of the time. Things like that i wouldn't have to bring my charger when going to the printer etc.
Thanks for your opinion. I will definitely consider it.
Main Rig:
CPU: i7 9750H
GPU: RTX 2070 MAX-Q
CPU: i7 3740QM
GPU: GTX 675MX 4GB
CPU: i5 7200U
GPU: HD 620
Server:
https://linustechtips.com/topic/921554-new-battery-worth-it/#findComment-11289888
Specs:
i7 3740qm
8Gb 1600MHz DDR3
128Gb SSD
750Gb HDD
https://linustechtips.com/topic/921554-new-battery-worth-it/#findComment-11290053
you need to repaste cpu and gpu with a good thermal compound
https://linustechtips.com/topic/921554-new-battery-worth-it/#findComment-11290056
My laptop battery died a while ago, but I just charge it straight to the wall and removed the battery.
If anything, it's just mildly inconvenient, but if you bring it everywhere and you don't want to run the risk of not having a power socket nearby, look for a battery reseller.
https://linustechtips.com/topic/921554-new-battery-worth-it/#findComment-11291495
Okay so i just replaced both the cpu and gpu therman paste and i saw a significant drop in temps under load. The idle temp didn't change all that much since the fan runs from very slow to off in idle -> 40-55° in idle. Under heavy lot i am not exceeding 85° now which is almost a 10° down from the stock thermal paste. The thermal paste was pretty solid and spread poorly, this makes me guess that it hasn't been replaced before and i doubt the owner before me had the knowledge to do so.
Main Rig:
CPU: i7 9750H
GPU: RTX 2070 MAX-Q
CPU: i7 3740QM
GPU: GTX 675MX 4GB
CPU: i5 7200U
GPU: HD 620
Server:
https://linustechtips.com/topic/921554-new-battery-worth-it/#findComment-11294990
check also the fans because dust could be an obstacle for the air flow
https://linustechtips.com/topic/921554-new-battery-worth-it/#findComment-11295027
Already did before applying the thermal paste. There wasn't too much in it, but definitely enough to lower the airflow a bit. Cleaned it all properly and it's working great! Also due to the lower temps in general the laptop is much quieter now, the fans stopped spinning up very aggressivly when just opening a few programs. I am absolutely in love with this laptop. It has all the ports one could ever need and everything is so modular. Really reminds me of the good old laptops days where nothing was soldered and hidden under the keyboard or something which i experienced in a hp pavilion which i sold recently due to that.
Main Rig:
CPU: i7 9750H
GPU: RTX 2070 MAX-Q
CPU: i7 3740QM
GPU: GTX 675MX 4GB
CPU: i5 7200U
GPU: HD 620
Server:
https://linustechtips.com/topic/921554-new-battery-worth-it/#findComment-11295073
what thermal paste did you use?
https://linustechtips.com/topic/921554-new-battery-worth-it/#findComment-11295087
10 minutes ago, Teddy07 said:
You can also google for a program that lets you adjust the fan speed manually depending on the load. I for example rather prefer a few more degrees than having a noisy laptop
Already tried that however i didn't find any that actually does something.
Very cheap arctic mx2. I know it's probably not the best one but i always served me well over the years. Using better thermal paste wouldn't change much probably. It's still a laptop and the main bottleneck cooling wise is still the fan and the heatsink probably.
Main Rig:
CPU: i7 9750H
GPU: RTX 2070 MAX-Q
CPU: i7 3740QM
GPU: GTX 675MX 4GB
CPU: i5 7200U
GPU: HD 620
Server:
https://linustechtips.com/topic/921554-new-battery-worth-it/#findComment-11295107
Artic mx2 offers only 5.6 W/mK  of thermal conductivity and that's not so good for laptops.
check for
-Thermal Grizzly Kryonaut 12.5 W/mK
-Phobya NanoGrease Extreme 16W/mk
they are much better
https://linustechtips.com/topic/921554-new-battery-worth-it/#findComment-11295187
check for
Yes i know, but do you really think it would make a significant difference using better paste? The mx2 has always performed quiet well for me, i'm happy with the current results however if better paste would lower the temps by another 10° i would definitely do that.
Main Rig:
CPU: i7 9750H
GPU: RTX 2070 MAX-Q
CPU: i7 3740QM
GPU: GTX 675MX 4GB
CPU: i5 7200U
GPU: HD 620
Server:
https://linustechtips.com/topic/921554-new-battery-worth-it/#findComment-11295219
44 minutes ago, sicily428 said:
I think another 5°/6° lower could be a good result with TGK but for 10°+ you need LM. Did you make a stress test of your system?
I  ran cinebench and firestrike a couple of times, i don't have time for a full stress test right now, but i will do that in the future and report back. I will probably do some extended gaming tests too since that tends to be more realistic espacially for a laptop.
Main Rig:
CPU: i7 9750H
GPU: RTX 2070 MAX-Q
CPU: i7 3740QM
GPU: GTX 675MX 4GB
CPU: i5 7200U
GPU: HD 620
Server:
https://linustechtips.com/topic/921554-new-battery-worth-it/#findComment-11295442
test it with aida64extreme stability test (cpu+gpu) for 30 minutes,
https://linustechtips.com/topic/921554-new-battery-worth-it/#findComment-11295448
Just another quick question i got. I just found out that HWInfo64 shows the battery wear level. For the current battery it displays 63% (which basically means it's almost dead right?). Is this percentage remotely accurate so that i can expect more than double the battery life compared to what i have right now ?
Main Rig:
CPU: i7 9750H
GPU: RTX 2070 MAX-Q
CPU: i7 3740QM
GPU: GTX 675MX 4GB
CPU: i5 7200U
GPU: HD 620
Server:
https://linustechtips.com/topic/921554-new-battery-worth-it/#findComment-11317905
