Seems fine to me. I personally would recommend the Ryzen 5 2600.
Ryzen 5 1600 @ 3.9 Ghz  | Gigabyte AB350M Gaming 3 |  PaliT GTX 1050Ti  |  8gb Kingston HyperX Fury @ 2933 Mhz  |  Corsair CX550m  |  1 TB WD Blue HDD
Inside some old case I found lying around.
https://linustechtips.com/topic/920285-first-pc-build/#findComment-11278007
15 minutes ago, SoulSen said:
So I'm creating a PC, and I need help making it right. I'm gonna use the PC for gaming, recording, editing (not heavy), and everyday use. https://pcpartpicker.com/list/gXF8J8, I'm in the US also.
No
buy an R7 1700 with a GTX 1050ti
PCPartPicker part list: https://pcpartpicker.com/list/zxNPV6
Price breakdown by merchant: https://pcpartpicker.com/list/zxNPV6/by_merchant/
CPU: AMD - Ryzen 7 1700 3GHz 8-Core Processor  ($259.46 @ OutletPC)
Motherboard: ASRock - AB350M Pro4 Micro ATX AM4 Motherboard  ($59.99 @ Newegg)
Memory: G.Skill - Trident Z 16GB (2 x 8GB) DDR4-3200 Memory  ($179.99 @ Newegg)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($43.85 @ OutletPC)
Video Card: EVGA - GeForce GTX 1050 Ti 4GB ACX 2.0 Video Card  ($189.89 @ OutletPC)
Case: Cooler Master - MasterBox Q300L MicroATX Mini Tower Case  ($38.99 @ SuperBiiz)
Power Supply: Cooler Master - MasterWatt 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($46.99 @ SuperBiiz)
Total: $819.16
Generated by PCPartPicker 2018-04-25 01:56 EDT-0400
https://linustechtips.com/topic/920285-first-pc-build/#findComment-11278018
Welcome to the forum!
Peroabally I'd go with the 1600/2600 instead of the 8400. It handles streaming a lot better, has more threads, and is around the same price. If you really want to go Intel, just make sure the board supports locking the chip at it's turbo speed.
@Streetguru Odd suggestion considering he said light editing. The 1050ti will give significantly worse performance in games.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/920285-first-pc-build/#findComment-11278023
3 minutes ago, dizmo said:
He also said recording
an R7 1700 will last a lot longer than a 1060 vs a 1050ti  in any event.
https://linustechtips.com/topic/920285-first-pc-build/#findComment-11278031
And yet, the 1600 gives the best of both worlds. If he's recording, he probably wants to have a decent experience. The 1050ti doesn't really give that.
https://linustechtips.com/topic/920285-first-pc-build/#findComment-11278039
Gaming at medium-high settings is still pretty good rather than overpaying for a 1060/580
https://linustechtips.com/topic/920285-first-pc-build/#findComment-11278051
6gb version of gtx 1060 is only slightly better than the 3 gb version.  not really good bang for buck.
120 gb ssd storage will run tight.  spend a bit more to get 250 gb.  especially since you're going to want to store plugins and such on it
PC Build: R5-1600.  Scythe Mugen 5.  GTX 1060.  120 GB SSD.  1 TB HDD.  FDD Mini C.  8 GB RAM (3000 MHz).  Be Quiet Pure Wings 2.  Capstone-550.  Deepcool 350 RGB.
Peripherals: Qisan Magicforce (80%) w/ Gateron Blues.  Razer Naga Chroma.  Lenovo 24" 1440p IPS.  PS4 Controller.
Audio: Focusrite (Solo, 2nd), SM57, Triton Fethead, AKG c214, Sennheiser HD598's, ATH-M50x, AKG K240, Novation Launchkey
Wishlist: MP S-87, iPad, Yamaha HS5's, more storage
https://linustechtips.com/topic/920285-first-pc-build/#findComment-11278318
which programs will you be using for editing?
https://linustechtips.com/topic/920285-first-pc-build/#findComment-11278320
Full disclosure: This is a Seagate employee. That being said, looking over your use-case and needs, give this suggestion a look:
PCPartPicker part list: https://pcpartpicker.com/list/PbKXbX
Price breakdown by merchant: https://pcpartpicker.com/list/PbKXbX/by_merchant/
CPU: AMD - Ryzen 5 2600 3.4GHz 6-Core Processor  ($199.98 @ SuperBiiz)
Motherboard: MSI - B350 TOMAHAWK ATX AM4 Motherboard  ($64.89 @ OutletPC)
Memory: ADATA - XPG GAMMIX D10 8GB (2 x 4GB) DDR4-3000 Memory  ($85.99 @ Newegg)
Storage: ADATA - Ultimate SU800 128GB 2.5" Solid State Drive  ($39.99 @ Amazon)
Storage: Seagate - BarraCuda 1TB 3.5" 7200RPM Internal Hard Drive  ($44.18 @ OutletPC)
Video Card: EVGA - GeForce GTX 1060 6GB 6GB SC GAMING Video Card  ($299.89 @ OutletPC)
Case: Corsair - 100R ATX Mid Tower Case  ($24.99 @ Newegg)
Power Supply: EVGA - 500W 80+ Bronze Certified ATX Power Supply  ($39.88 @ OutletPC)
Total: $799.79
Generated by PCPartPicker 2018-04-25 14:51 EDT-0400
Seagate Technology | Official Forums Team
IronWolf Drives for NAS Applications - SkyHawk Drives for Surveillance Applications - BarraCuda Drives for PC & Gaming
https://linustechtips.com/topic/920285-first-pc-build/#findComment-11279831
