Honor 8 Lite frame is bent.
Solved by Guest The Viking,
Really sucks mate, but can't expect much if you fall with the phone...
Have you check Aliexpress for a new frame? You can have them for a couple of bucks.
the good thing from chinese phones is you can find/buy all the parts needed to fix them yourself or through a shop (and when I say all parts, i really mean ALL parts...)
or maybe it's too bothersome/expensive and you prefer getting a new one.
