Ok so I have had this rig for a while, and yesterday reinstalled Windows 10 on a different hard drive because the one that was in my rig was super old. But after a day of getting Battlefront 2 downloaded, I have to be at Low settings and 25% resolution scale to achieve 60 or so FPS. I don't know what the issue is, because I was able to play the game at Ultra settings and still get 75+ FPS with hardly any dips. I tried using MSI Afterburner to overclock my GPU, but it still isn't doing anything. I used MSI Kombustor to check and see how many FPS I was getting in the stress test and was only getting on average 16 FPS and on occasion getting 18 FPS. It also said that only 300MB of VRam was being used out of 3GB, and before I did the HDD switch, I normally got 110+ FPS and it was using about 2.5GB of the VRam. Is there any way I could fix this? I'm just so confused.
Also here are my specs:
FX-6300 ~ 3.5GHz
GA-880GM-USB3 Gigabyte Motherboard
8GB Corsair XMS3 1600MHz DDR3 RAM
600W OCZ PSU
Gigabyte GTX 1060 OC 3GB
120GB HDD (For OS)
500GB HDD (For games)
"...Hang on a sec..."
https://linustechtips.com/topic/916941-help-gtx-1060-underperforming/
3 minutes ago, Ukiryah said:
No I don't think so. I've never had this issue before UNTIL today. I'm completely lost as of now.
... have you re-enabled windows game mode, or software optimization(s)? What is the speed of your HDD versus your old one?
In search of the future, new tech, and exploring the universe! All under the cover of anonymity!
Just now, Wh0_Am_1 said:
... have you re-enabled windows game mode, or software optimization? What is the speed of your HDD versus your old one?
Windows Game Mode is enabled, I have pretty much every software optimization programs I can think of, and I'm almost positive it's 7200RPMs.
2 minutes ago, Ukiryah said:
Wrong it's 5400RPMs
That could be it, but it is hard to tell for sure... I simply don't have the expertise beyond this point.
@Ukiryah
Did you let Windows go through its update process?
Latest version is 1709, Build 10.0.15254.313 (?).
Also, are all your motherboard, and chipset drivers downloaded and installed?
Gigabyte doesn't have official drivers for Windows 10, but Windows 8.1 (and *some* Windows 7) drivers are usually compatible with Windows 10 as well.
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
2 minutes ago, -rascal- said:
@Ukiryah
Also, are all your CPU, motherboard, and chipset drivers downloaded and installed?
I'll have to check on windows update. I turned it off because I hate windows but if that's the issue then I'll fix it. And I checked and it seems all the drivers are installed
It's still doing the same thing even after updating. I'll figure it out later.
Boi NVIDIA has much better performance and a cheaper price than AMD (Yes AMD is good but I prefer NVIDIA GPUs over AMD) The 6GB GTX 1060 has a 6% performance increase over the RX 580 8GB. It's all peripherals.
But the one you have is 3GB version, am I right? :v
Just in case, try to wipe your video drivers with DDU.
Also, did you select for the application to use dedicated graphics card in NVIDIA Control Panel?
Ex-EX build: Liquidfy C+... R.I.P.
Ex-build:
Meshify C – sold
Ryzen 5 1600x @4.0 GHz/1.4V – sold
Gigabyte X370 Aorus Gaming K7 – sold
Corsair Vengeance LPX 2x8 GB @3200 Mhz – sold
Alpenfoehn Brocken 3 Black Edition – it's somewhere
Sapphire Vega 56 Pulse – ded
Intel SSD 660p 1TB – sold
be Quiet! Straight Power 11 750w – sold
I might have I need to check.
  • 3 weeks later...
5 minutes ago, Ukiryah said:
So I got the computer working again. It was the hard drive.
Your CPU will still bottleneck your 1060 3GB in some situations.
Judge a product on its own merits AND the company that made it.
How to setup MSI Afterburner OSD | How to make your AMD Radeon GPU more efficient with Radeon Chill | (Probably) Why LMG Merch shipping to the EU is expensive
Oneplus 6 (Early 2023 to present) | HP Envy 15" x360 R7 5700U (Mid 2021 to present) | Steam Deck (Late 2022 to present)
Mid 2023 AlTech Desktop Refresh - AMD R7 5800X (Mid 2023), XFX Radeon RX 6700XT MBA (Mid 2021), MSI X370 Gaming Pro Carbon (Early 2018), 32GB DDR4-3200 (16GB x2) (Mid 2022
Noctua NH-D15 (Early 2021), Corsair MP510 1.92TB NVMe SSD (Mid 2020), beQuiet Pure Wings 2 140mm x2 & 120mm x1 (Mid 2023),
Yes I know this. I am currently looking for a job to upgrade my PC. You gotta also take note that I got the computer basically for free (The only bought items were the FX-6300 and the 1060, but I got the 1060 for Christmas. Luckily it was $190 at that time.)
  • 4 weeks later...
Yes I know. Battlefront 2 stutters a lot on any preset setting unless I turn 3 pre rendered frames on in the NVIDIA control panel, but it's consistent at 70+fps 1080p Ultra. But I'm upgrading to an i7-6700k so I won't have those issues.
If the 6700K is a similar price to the 8700K then I'd recommend that over the 6700K.
  • 3 weeks later...
Well I have already acquired a 6700k from a relative for free with a mobo and 16GB of DDR4 2800MHz RAM. I wont need to purchase new parts because I can just use these, although slightly older, better parts than I had before.
To be honest, if it fitted your budget, I would have gone for the 1060 6 GB instead. This card can be seen as kind of a “1060 Ti” having not only more VRAM but also more power (CUDA cores 1280 vs. 1152) compared to the 3 GB version. The performance boost is often worth the small price difference.
