Problems with 4790k overheating
Go to solution Solved by Jurrunio,
the problem is the pitfully weak stock cooler. The free-of-charge way is to undervolt the CPU, the more reasonable way (considering this chip is overclockable), is to buy an aftermarket cooler. Hyper 212 is the bare minimum.
The cpu runs at around 40-50 degrees while not gaming and goes up to 85 degrees when gaming. Thermal paste and cooler are stock. I did CPU stress test and temperatures went up to 90 degrees in like 3-4 min and then my computer crashed. What should i do, should the processor regulate its temperature so it never comes so high, where do you think its problem?
https://linustechtips.com/topic/915833-problems-with-4790k-overheating/
update your cooler to like a hyper 212 evo or something if your on a budget.  If you dont wana replace the cooler then replace the thermal paste
Current Rig=  AMD Ryzen 9 5900x, Asus Crosshair Hero VIII, EVGA RTX 3070 FTW3 ultra, 32gb Corsair Vengence Pro RGB 3000hz White, EVGA 750 P2 PSU, 1TB Samsung 980 Pro, 500gb samsung 860 evo, 250GB Samsung 850 evo, 2TB Samsung 970 Evo Plus, 2TB seagate firecuda sshd,  LianLi PC 011 Dynamic XL ROG edition, Corsair h150i elite capelix
2 minutes ago, Valkyrie Lenneth said:
why in teh fuck do they still include those shitty hunks of egg smashers in i7 boxes like seriously
Because Intel is premium :P
Jokes aside, replace your thermal paste at least and if you can get an after-market cooler... There are cheap ones (20-30$) that could a much better job than yours.
CPU: Ryzen 7 9800X3D Cooler: Noctua NH-D15 Black Mobo: Gigabyte X870E Aorus Pro GPU: Sapphire Nitro+ 9070 XT RAM: G.Skill 2x16GB @ 6400 MHz SSD: PNY XLR8 2TB PSU: Corsair RM1000x Case: Fractal Design North Monitor 1: Asus XG27AQWMG(280Hz) Monitor 2: Asus VG259QM (240Hz)
I usually edit my posts immediately after posting them, as I don't check for typos before pressing the shiny SUBMIT button.
Unraid Server
CPU: Ryzen 5 7600 Cooler: Noctua NH-U12S Mobo: Asus B650E-i RAM: Kingston Server Premier ECC 2x32GB (DDR5) SSD: Samsung 980 2x1TB HDD: Toshiba MG09 1x18TB; Toshiba MG08 2x16TB HDD Controller: LSI 9207-8i PSUCorsair SF750 Case: Node 304
Desktop benching:
Turn the voltage down and the fan up. Problem solved. Temps are fine.
Well, i tryed putting voltage down from 1.2 V to 0.9 V. No sucess, you guys think cooler its stock cooler fault. I read some forums and other people sad they also have issue with i7 4790k overheating. Is it worth it to buy Hyper 212 ? Or should i just try to replace termal paste?
Do both. If it isn't crashing while being used correctly, there isn't an issue. Shouldn't be dropping the voltage that low anyway. It will do that by itself when idle.
2 hours ago, Valkyrie Lenneth said:
i5 and stock cooler = no
i7 and stock cooler = LKIGDJLDAKGJKLDSAJGHKEGHEAGJHAEGKJ
They don't. Devil's Canyon is the last one to include a stock cooler with unlocked chips.
Replacing the thermal past will help some. I'd recommend getting a Cryorig H7 though.
Make sure to quote or tag me (@JoostinOnline) or I won't see your response!
PSU Tier List  |  The Real Reason Delidding Improves Temperatures"2K" does not mean 2560×1440
well ty fk for that lmao xD they finally understood it lol
OH GOD WHAT ARE YOU DOING AN i7 ON THE FUCKING STOCK COOLER? WTF!!!@!!?!#&U# Get at least a CryoRig H7 - Avoid the 212 Evo it is trash.
CPU: Core i9 12900K || CPU COOLER : Corsair H100i Pro XT || MOBO : ASUS Prime Z690 PLUS D4 || GPU: PowerColor RX 6800XT Red Dragon || RAM: 4x8GB Corsair Vengeance (3200) || SSDs: Samsung 970 Evo 250GB (Boot), Crucial P2 1TB, Crucial MX500 1TB (x2), Samsung 850 EVO 1TB || PSU: Corsair RM850 || CASE: Fractal Design Meshify C Mini || MONITOR: Acer Predator X34A (1440p 100hz), HP 27yh (1080p 60hz) || KEYBOARD: GameSir GK300 || MOUSE: Logitech G502 Hero || AUDIO: Bose QC35 II || CASE FANS : 2x Corsair ML140, 1x BeQuiet SilentWings 3 120 ||
LAPTOP: Dell XPS 15 7590
TABLET: iPad Pro
PHONE: Galaxy S9
She/they
1) The stock cooler works if you're running stock speeds. I used it on my 4790k for awhile. I even did some very slight overclocking after replacing the thermal paste.
2) Show a little civility. Proper grammar goes a long way.
3) The Hyper 212 Evo is NOT trash. It's only recently been overtaken by the H7 and king budget cooler, and it's cheaper.
No, but the Evo has a shitty fan and is damn near impossible to mount.
TABLET: iPad Pro
PHONE: Galaxy S9
She/they
They don't any more with k skus. This CPU was released when they still included them.
stock cooler didnt even worked good with my 2600k on stock settings. And this badboy was soldered.
CPU: Ryzen 7 5800x3D | MoBo: MSI MAG B550 Tomahawk | RAM: G.Skill F4-3600C15D-16GTZ @3800CL16 | GPU: RTX 2080Ti | PSU: Corsair HX1200 |
Case: Lian Li 011D XL | Storage: Samsung 970 EVO M.2 NVMe 500GB, Crucial MX500 500GB | Soundcard: Soundblaster ZXR | Mouse: Razer Viper Mini | Keyboard: Razer Huntsman TE Monitor: DELL AW2521H @360Hz |
The H7 isn't much better.  I've used both.  The Evo is harder to mount because it's compatible with so many more sockets.
