Quiet Cooler For R5 1600
12 hours ago, Nazim Pasa said:In fact I don't want a cooler with a 92 mm fan. There is plenty of sites, you can just say the model name or give link from Amazon. Viper can be but I read many reviews that said the Viper model fans are loud.
The Viper fan is noisy at high or max rpm but most fans are. It can be lowered to ~600rpm where it should be fairly quiet.
Why not a 92mm fan? The PR Slim is quieter and performs similarly to the Freezer 33.
The Pure Rock with a 120mm fan performs similarly to the PR Slim but is a bit quieter at load.
If you want to oc, a beefier cooler like the the Mugen 5 Rev. B would be good: https://www.amazon.com/Mugen-Rev-CPU-Cooler-Support/dp/B06ZYB8K77/ref=sr_1_4?s=electronics&ie=UTF8&qid=1523476637&sr=1-4&keywords=scythe+cooler
