Making a torrent box
Solved by Jarsky,
You can then mount your share to Raspbian such as this: https://www.htpcguides.com/mounting-storage-drives-in-debian-linux/
Then once you've confirmed that the network share is configured properly, set the download folder in Deluge to the share path mounted on Raspbian.
Personally, on my storage I have a seperate folder, which uses a "service account" that has full read/write to that folder - and thats the network folder and user/pass I use for doing this with. Better for security.
So mine looks like this (using Ubuntu + ruTorrent)....
Storage Config (through Windows Server):
SMB Config:
Torrent Client (ruTorrent) download path:
