11 minutes ago, Jimboynoob said:
Your cooler is equal or better to any 120mm AIO
You need a 240mm AIO to potentially go lower
https://linustechtips.com/topic/914185-cooler-master-ml120l/#findComment-11219420
I see thank you. do you think my cooler is not working? it views 80+ c on Aida( i7 4790k stock).
But when using Real temp while playing+streaming, It only views 60-70c.
https://linustechtips.com/topic/914185-cooler-master-ml120l/#findComment-11219531
Just reapply your thermal paste most likely, unless something happened to your heat pipes/vapor chamber which is unlikely.
https://linustechtips.com/topic/914185-cooler-master-ml120l/#findComment-11219563
