I just got a nice deal on a 1060 6gb last week *FIRE* but my G4400 is holding it back, my only budget left for upgrade is for a G4560 but I heard it still bottleneck the 1060 for a little bit. Then i saw G4600 100mhz higher than G4560 for only 8$ more. Will the G4600's slightly higher clock help alleviate bottllenecking???
https://linustechtips.com/topic/913829-does-100mhz-make-a-difference/
on the CPU? not enough that you would want to spend the money on it
Primary System
  • CPU
    Ryzen R6 5700X
  • Motherboard
    MSI B350M mortar arctic
  • RAM
    32GB Corsair RGB 3600MT/s CAS18
  • GPU
    Zotac RTX 3070 OC
  • Case
    kind of a mess
  • Storage
    WD black NVMe SSD 500GB & 1TB samsung Sata ssd & x 1TB WD blue & x 3TB Seagate
  • PSU
    corsair RM750X white
  • Display(s)
    1440p 21:9 100Hz
if it's bottlenecking, yes, any little bit will help, but what you really need is 2 more actual cores.  As said above, I wouldn't go spending significantly more for it when you could save for something a lot better.  It'll help, but not that much.
no i5 or above, no talk
Desktop benching:
remember there are quad core i3s now
he's on LGA 1151 v1 still, dont need upgrade to LGA 1151 v2 just yet
Desktop benching:
Yeah it's not a realistic upgrade opportunity at the moment (shh don't tell him about this) but still worth noting.  Generally speaking, the "i5 minimum" doesn't really apply anymore imo because of what I said.
BIOS flash if it's out of warranty
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
first,try flash bios,and i3 8100。
secend,G4400,or skylake is interesting,you could try to overclocking cpu's external clock,外频xD
last,i think 8 dollar is not a big one for american,maybe
i am using an G4560,for about $46.792,¥295.
The biggest difference between G4600 and G4560 is the HD630 and HD610,i think9_9
0.1Ghz can't change anything,I think.
56 minutes ago, drkknghtavngr said:
G4560 and g4600 is 4 threads
Gah, so used to the older G series.
8$ for 100mhz then... Probably not worth it.  ~10% price for ~3% performance unless I'm missing something.  i3 looks to be roughly double the price for 10%-20% more performance, hmmm.
Honestly I would just get the 4560 after looking at comparisons.  Though only if I was looking to upgrade to i5/7 later.  R3 1200/2200g also has merits at the low end if you don't already have the platform, mainly because it can be overclocked.  R3 looks to be something like 50% faster with overclocking and 25%-35% faster without an OC.  Price/performance is roughly equal between the two.
