Baking a graphics card (need advice)
Solved by azX_,
Anyways I went ahead with the baking and it was successful
What I did was
- dissemble the heatsink, leaving the gpu board exposed
- wrap everything in aluminium foil but leaving the gpu die exposed
- temp at 190c
- frequently check for 1~2 minutes
- 10 minutes bake
- leave until room temperature
- reassemble it back, applied new thermal compound
