Hitfilm Pro
Go to solution Solved by yolosnail,
Personally I would probably go with Vegas, but that is probably because I've been using it for years. I think it's one of the easiest editors to use, but it really depends on what you will be using the most. Do you really need the compositing features of Hitfilm? Because if you do, then go for it. But if you don't, then I would just go with Vegas.
I'm strongly considering purchasing Hitfilm Pro as I have been waiting for a $200 sale for a while. However, some say that Sony Vegas is superior for the editing experience, but Hitfilm is better at compositing and also includes Mocha. (I'm not including Adobe's software in this since it's a monthly subscription.) Is there any reason not to purchase Hitfilm Pro as my main editor and compositor?
PC Specs:
CPU: AMD 1700x Cooler: Corsair H100i V2 Motherboard: Asus Crosshair VI Hero RAM: 4 * 8GB G.Skill RGB DDR4 Graphics: EVGA GTX 1080 Ti SC2 Storage: Samsung 960 EVO 500GB Case: Fractal Design Meshify C PSU: EVGA 750w G3 Monitors: Dell SG2716DG +  2x Dell U2515H
Freenas specs:
CPU: Intel Xeon E5-2650 V2 Cooler: Some noctua cooler Motherboard: Supermicro X9 SRL-F RAM: 8 * 8GB Samsung DDR3 ECC Storage: 6 * 4TB Seagate 7200 RPM RAIDZ2 Controller: LSI H220 Case: Phanteks Enthoo Pro PSU: EVGA 650w G3
Phone: iPhone 6S 32 GB Space Grey
https://linustechtips.com/topic/912620-hitfilm-pro/
Laptop:
HP OMEN 15 - Intel Core i7 9750H, 16GB DDR4, 512GB NVMe SSD, Nvidia RTX 2060, 15.6" 1080p 144Hz IPS display
PC:
Vacancy - Looking for applicants, please send CV
Mac:
2009 Mac Pro 8 Core - 2 x Xeon E5520, 16GB DDR3 1333 ECC, 120GB SATA SSD, AMD Radeon 7850. Soon to be upgraded to 2 x 6 Core Xeons
Phones:
LG G6 - Platinum (The best colour of any phone, period)
LG G7 - Moroccan Blue
https://linustechtips.com/topic/912620-hitfilm-pro/#findComment-11203985
I've tried the free Express, Vegas Pro, and Premiere Pro CC. I prefer Express over Vegas Pro but Premiere beats then all
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/912620-hitfilm-pro/#findComment-11204001
Have you tried ShotCut? It's a bit steep to learn but I use it for YouTube videos and it's free. I found it does a very good job of making videos look pro.
Intel Core i7 4790K 4.8GHz | MSI Z97 Gaming 5 | 32GB 2133MHz CL7 DDR3 | nVidia GeForce GTX 1070 with Custom BIOS | Samsung 850 Evo 500GB | 3TB Seagate FireCuda SSHD | 2TB Seagate FireCuda SSHD | Corsair CX750M  | Custom 240mm all-in-one liquid cooler | Broadcom NetXTREME 5709c Dual Gigabit NIC | Cougar MX330 mid-tower chassis | Windows Server 2008 R2 Datacenter
https://linustechtips.com/topic/912620-hitfilm-pro/#findComment-11204038
I definitely need the compositing features for short film production. The interface seems easy to use after some practice with the free version.
I've been using the free version of Hitfilm for over a year which is fine for gaming editing and the like, it's just that I'm finding uses for more advanced features now.
PC Specs:
Freenas specs:
https://linustechtips.com/topic/912620-hitfilm-pro/#findComment-11204106
-Moved to Programs, Apps, and Websites-
https://linustechtips.com/topic/912620-hitfilm-pro/#findComment-11204114
