Budget?
(I'm not familiar with Denmark stores other than power.dk, can you link me to others or can you buy from Germany?)
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
Just now, ingolx said:
https://www.proshop.dk/
its probably the best danish web shop to buy from
Budget?
Full Specs
Helios EVO (Main):
Delta - Laptop
Something like this?
https://www.proshop.dk/Stationaer-PC-Mac/MSI-Aegis-Ti3-8RF-SLI-006EU/2642150
Can't speak danish so it's a bit tricky to pick parts, but the prebuilt one is probably as good as it's going to get :P
If you want my attention, quote meh! D: or just stick an @samcool55 in your post :3
Spying on everyone to fight against terrorism is like shooting a mosquito with a cannon
1 minute ago, ingolx said:
money is not a problem okay
What are you aiming for? Frame rate? Resolution?
Need monitor/keyboard/mouse/windows?
Full Specs
Helios EVO (Main):
Delta - Laptop
If money is genuine not an issue, why not go all out and get something like this?
https://www.caseking.de/en/pc-welt-hoellenmaschine-8-i9-7980xe-4-5-ghz-nvidia-titan-xp-sli-sipc-210.html
Yes it's from germany but who cares! It's unique and basically as good as it's going to get, it even comes pre-overclocked.
i have keyboard, mouse. windows and monitor
im aiming for an okay resolution bot mostly fps
As in what resolution monitor do you have? What hz is it?
Full Specs
Helios EVO (Main):
Delta - Laptop
3 hours ago, JDE said:
Budget?
komplett.dk is probably a good store. im familiar with Komplett.no which is the Norwegian equivelent. They also build pc`s within  some limitations.
Im assuming OBS streaming
https://www.komplett.dk/product/11282/pc-tablets/komplett-pc/komplett-gamer-premium/komplett-gamer-premium-a145-gtx1070ti#
should be quite nice value for money.
https://www.komplett.dk/product/11251/pc-tablets/komplett-pc/komplett-gamer-xtreme/komplett-gamer-xtreme-a250#
bit more expencive but the extra cores and better GPU is quite nice
https://www.komplett.dk/product/11322/pc-tablets/komplett-pc/komplett-gamer-xtreme/komplett-xtreme-threadripper-edition#
I would never go higher than this in terms of cores. however you should configure it with an higher end GPU, something like an 1080
EDIT: Yes im going with Ryzen/Zen parts due to there being a need for cores when streaming OBS. And core for Core the Ryzen parts are cheaper (as far as a i know)
2 hours ago, ingolx said:
thanks goldenlag
Please use the quote function or @
Me next time @ingolx
No problem, im not the greatest at picking out pc's and i didnt have too much time to look around. Hope you enjoy you next pc and good luck streaming
