New GPU from AMD with the help from Intel.
Wccftech AMD Radeon RX Canis
Process 10nm ++ (Intel)
Architecture Canis 10
Stream Processors 10240
Core Clock (Boost) 1800 MHz (2441 MHz)
Memory 32GB HBM4
Bandwidth 4 TB/s
Peak Performance 50 TFLOPs
Die Size 400mm2 (x2)
GPU Type MCM
Interconnect Unknown (TSV based)
Feature Level Direct3D 12_2
TDP 350W
Power Connectors 3x 8-pin
Expected MSRP $999
Launch 2H 2018
https://wccftech.com/amd-project-canis-flagship-intel-joint-venture/
https://linustechtips.com/topic/911630-amdintel-project-canis/
49 minutes ago, RorzNZ said:
but will it blend?
Technically it's Intel and Radeon Technologies blended together.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/911630-amdintel-project-canis/#findComment-11194875
~~Kuroneko~~
- Ryzen Threadripper 1950X 16-Core
- Corsair H115i Pro 280 Liquid Cooler
- Asus X399 ROG Zenith Extreme MB
- 2x Nvidia Titan V
- Corsair 64GB (4x16GB) DDR4 3000MHz
- Samsung 960 Pro Series 1TB M.2 SSD
- Western Digital RED Pro 6TB 64M SATA
- Corsair AX1500i Titianium PSU
- Fractal Design Define R6 Blackout
- 3x Noctua NF-A14 Industrial 140mm 3000RPM Fans
~~Chibineko~~
- Ryzen 7 2700X 8-Core
- Corsair H115i 280 Liquid Cooler
- Asus X470-F ROG Strix  MB
- 2x MSI Vega 64 Wave Liquid Cooled
- G.Skill Sniper X 32GB (2x16GB) DDR4 3600MHz
- Samsung 960 Pro Series 512GB M.2 SSD
- Samsung 850 EVO 500GB SSD
- Corsair AX1200i 80+ Platinum
- Fractal Design Define R5
- 5x Noctua NF-A14 Industrial 140mm 3000RPM Fans
https://linustechtips.com/topic/911630-amdintel-project-canis/#findComment-11194885
Canis Majoris is the largest star second largest star in the known universe, it also happens to be the code name of a leaked Intel and AMD joint venture named Project Canis. The JV aims to unify Intel’s outstanding fabrication facilities and RTG’s graphics ambitions. In simpler words, RTG will be designing the GPU and Intel will be fabricating it. In an oddly gracious gesture, GloFo decided to allow this partnership to go ahead without any financial penalties for – old times sake (or a lot of $$$).
Radeon’s new flagship Radeon RX Canis to be manufactured by Intel foundries, will be supporting 10,240 SP and 4 TB/s HBM4
Reliable sources have told us that the JV documentation was personally carried to Intel HQ by Raja Koduri and represents the start of a burgeoning alliance between the two chip powerhouses. AMD’s RTG division has always been quite good at the designing part of the chip process and with Intel’s foundries in the equation (which are hands down the best on the planet I might add) this is going to utterly disrupt the entire graphics industry.
SOURCE https://wccftech.com/amd-project-canis-flagship-intel-joint-venture/
https://linustechtips.com/topic/911630-amdintel-project-canis/#findComment-11194902
lol rekt
Current LTT F@H Rank: 24    Score: 10,097,484,643   Stats
Yes, I have 9 monitors.
My main PC:
OS: Windows 11
CPU: Ryzen 9 9950X
Cooler: Noctua NH-D15
Mobo: Asus ProArt X670E Creator WiFi
RAM: 96GB Trident Z Neo @6400 CL32
GPU: RTX 4090 Founders Edition, Radeon Pro WX 5100
PSU: Corsair RM1000e
SSDs: Samsung 990 Pro 4TB NVME, Samsung 970 evo plus 1TB NVME, 2x Samsung 870 evo 2TB, Samsung 860 evo 1TB, Samsung 970 evo 500GB NVME
Case: Fractal Design Define R5 Black w/ Tempered Glass Side Panel Upgrade
Monitors: 9 Monitors: Alienware AW3423DWF 3440x1440@165Hz, Acer H236HLbid 1080p@77Hz, HP D7z72AA 1080p@60Hz, Dell Inspiron 24 3459 1080p@60Hz(used only as display), Dell U2724D 1440p@120Hz, ASUS VP228 1080p@60Hz, 2x HP ZR2440W 1200p@60Hz
unRAID server (Plex, Backups, NAS, Duplicati, game servers):
OS: unRAID 7.1.4
CPU: Ryzen R9 3900X
Cooler: Noctua NH-U9S
Mobo: Asus ROG Strix X470-F
RAM: 64GB G-Skill Ripjaws V @ 3200MHz
PSU: EVGA G3 850W
Total Storage: Raw: 94TB, Usable: 64TB
SSD: Samsung 990 Pro 2TB NVME, Teamgroup 4TB NVME
HDDs: 4x HGST Dekstar NAS 4TB @ 7200RPM (3 data, 1 parity) + (7x Seagate Ironwolf NAS 8TB + 2x Toshiba N300 NAS 8TB in ZFS)
Case: Fractal Define 7 XL
Other: Added 3x Noctua NF-F12 intake, 2x Noctua NF-A8 exhaust, Inatek 5 port USB 3.0 expansion card with usb 3.0 front panel header
https://linustechtips.com/topic/911630-amdintel-project-canis/#findComment-11194906
First Canis is dog in Latin
Second WCCF got you, fool :P
(I watched Linus's video earlier while still very much asleep and didn't realise what day it was)
Main Rig:-
Server:-
https://linustechtips.com/topic/911630-amdintel-project-canis/#findComment-11194908
April Fools!
https://linustechtips.com/topic/911630-amdintel-project-canis/#findComment-11194934
Memory 32GB HBM4
Bandwidth 4 TB/s
GPU Type MCM
TDP 350W
Expected MSRP $999
Launch 2H 2018
Nice b8 m8
I rate it 5/7
https://linustechtips.com/topic/911630-amdintel-project-canis/#findComment-11195594
