Using loop counters to input files (Python3)
Solved by Guest,
These worked:
From what @mariushm and @M.Yurizaki wrote:
x = 1 while x <= 5: y = 1 while y <= 2: infile = open("Team%d_Round%d.txt" %(x,y), "r") score = infile.readline() while score != "": print (score, end="") score = infile.readline() print () y += 1 x += 1
And this is what @vorticalbox wrote:
for x in range(1,6): for y in range(1,3): with open("Team%d_Round%d.txt" %(x,y), "r") as f: for line in f.readlines(): print(line)
Thank you!
Note: I changed them a bit so that they print the results from the first round first and then the second round (in my program), other than that it's the same.
